| Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt |
| deskam When using deskam to create a path for a plasma machine, is there a way to set the direction of travel when cutting the 'island' different than the 'boundary". I have tried the 'reverse dir of selected' , but this leaves the entry cut in on the wrong side. It seems that it changes the island to a boundary. Due to the characteristics of a plasma flame, the 'good' side is the right side of the flame when the torch is moving away from you.
__________________ D. Paulson |
| You done everything half right it seems, if you change the direction of the contour you must also change the side of the line you are compensating to. EG: If you were staying to the left of the line previously then after you reverse the direction of the entity you must now compensate to the right of the line. Hope this helps.
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't" Greetings From Down Under Dave Drain Akela Australia Pty. Ltd. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| DeskCNC and DesKAM, what's the difference? | Monte | Carken Products (Deskam, DeskCNC etc) | 1 | 03-12-2005 02:13 PM |
| plasma cutter with deskam | guy | CNC Plasma and Waterjet Machines | 0 | 02-14-2005 04:34 PM |
| does deskam only output metric gcode? | july_favre | Carken Products (Deskam, DeskCNC etc) | 1 | 04-23-2004 04:44 PM |
| deskam to master5 post processor setup help | geesville | Mach Software (ArtSoft software) | 0 | 08-16-2003 11:06 AM |
