Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 02-22-2007, 05:04 PM
Gold Member
InspirationTool is on a distinguished road
Default feed override and manual jog speed settings?
Somehow my default feed override got set high, and I can't find out where to set it back to normal. It's driving me NUTS. I've looked at all the config files, config screens, and the documentation, and I'm somehow missing it. I have to fix this every time I start the program OR hit the E stop.
I *HATE* the fact that the feed override controls both the feed override AND the jog override. You can't change the feed without changing the jog. That means if I want a faster feed (10 ipm vs 5 ipm) on the next jog I might stall out the steppers (60 ipm vs 30 ipm.)
Also, I'd like to set the default manual jog speed. That is less annoying but still annoying.
Does anybody got the arrow keys working to jog the machine? That's not working for me either.
Thanks!
-Jeff
Mastercam 9.1 default settings Fatty Mastercam 2 06-29-2006 12:04 AM
Mach 3 & Feed Rate Override aus-newb Mach Lathe 1 11-21-2005 07:56 PM
Feed Override SCOJEN DIY-CNC Router Table Machines 0 01-24-2005 01:56 PM
MAch 2 feed settings?? replicapro Mach Software (ArtSoft software) 10 07-27-2004 03:42 PM
Is there a default feed rate ? and if so can you change it? fyffe555 TurboCNC 0 02-08-2004 09:09 PM
