| Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt |
| Ok here is what i did; 1. I downloaded a dxf file form internet. 2. I opened it up in deskcnc. 3. I see the drawing in cam mode. 4. I then move it from its org. place and place it closer to my 0,0 useing the edit drop down box and use the move button 5. I sel single and click on the inner holes to be cut away from the spokes of the gear useing (contour). 6. Then I go to run machine (to create my tool paths) 7. Now I go to (machine mode). 8. I go and hit the (Go button); It then comes up and tells me bad character line 198.... But there is no line 198, The line code skips every even # thru out the code. WHATS UP WITH THIS? IS IT WRONG OR RIGHT ? OR DID I DO SOMETHING WRONG? 9. By the way I'am new to this. Thanks Brady |
Hi Brady, First ensure that you have the correct post processor selected, Options->Misc and at the bottom select ISO-GCode-non modal. Once you have moved your part, be sure to 'deselect all' and then select the parts that you need. Chose a cycle, generate the tool path and click on 'run machine', DeskCNC will prompt you for a file name, click save or append depending on what you want and then you will enter the 'Edit' screen. Hope this helps, Greg |
| Greg, I'm not working with a stl file format. I'm not understanding what you are talking about other than this. To tell you the truth I really dont know what an stl is for. I'm really new to this. I cant even begin to figure out what all this is, (File foremat and what programs produce these formats) such as: 1. stl ? 2. stl for rotary ? 3. Hpgl ? 4. open point cloud ? 5. gerber ? 6. digitizer ? 7. foam cutter ? I would really like to know how and what all i need. But back to the problem You think im not doing it right. and you are more than likely right yourself its just that i really dont have a clue. shed the light my way. Thanks Brady |
| Mold making with Deskcam | Jon D | Carken Products (Deskam, DeskCNC etc) | 2 | 02-08-2007 04:41 PM |
| ReOrdering lines | rherman | BobCad-Cam | 0 | 12-21-2006 12:34 PM |
| CAD HELP: 4 lines to 1 box/object how to? | FireFghtr | General CAM Discussion | 7 | 02-24-2006 04:03 PM |
| Can't see lines | Mr.Chips | TurboCAD/CAM | 4 | 04-03-2005 11:29 AM |
| Need help extra lines in dxf | carlnpa | Mach Software (ArtSoft software) | 3 | 03-19-2005 04:48 PM |
