Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 02-03-2007, 12:12 PM
dmparrott's Avatar
dmparrott is on a distinguished road
DeskCNC question - help!
Hi guys,
I am in the process of converting my mill/drill to CNC and need some help. I am using a Xylotex 3-axis board with the 495 oz. motors. When I recieved these items, I hooked them up and ran the motors with a simple program from K-cam3. Everything worked perfectly the first time out so I know I had everything hooked up correctly. But now I want to set up the DeskCNC software that I am going to use, but it comes with its own controller board. The literature that came with it is not very specific. So now I need help with how to hook up the two boards without frying them! Has anyone out there had experience with this situation? Any help will be much appreciated. Thanks.
Dennis
Old 02-03-2007, 03:10 PM
belli is on a distinguished road
Smile DeskCNC breakout board
Hi ,
There is another possiblity, purchase a DeskCNC breakout board and this will simplify all your wiring headaches, see http://www.cncdirect.co.za/htm/cnc.html
Regards
Greg
Old 02-03-2007, 03:11 PM
bbergami is on a distinguished road
Try this.
http://www.deskcnc.com/controller2nd.html
Just hook up the appropriate step/dir output to your xylotex board.
Bert
Old 02-15-2007, 06:38 PM
dmparrott's Avatar
Thanks for your help guys. I went ahead and wired up the two boards after I decoded which pins on the IDC connector mated with the pins on the parallel port. I only hooked up the step and direction outputs and lo and behold, it worked! I'm in the process of installing the steppers on the mill now and hope to get it up and running soon. I'd be glad to post some pics of my progress if anyone has any interest. Thanks again.
Dennis
DeskCNC to Mach3 Question WarrenW Carken Products (Deskam, DeskCNC etc) 4 12-31-2005 11:29 AM
Need help with deskcnc BUD B General CAM Discussion 1 12-31-2005 06:49 AM
Deskcnc Question WarrenW Carken Products (Deskam, DeskCNC etc) 4 11-19-2005 09:37 AM
DeskCNC wmgeorge Carken Products (Deskam, DeskCNC etc) 6 09-30-2005 06:55 PM
Bobcad and DeskCNC question CNCadmin BobCad-Cam 6 01-21-2005 11:00 PM
