| Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt |
| Got hit by lighting a year ago last September. Had to replace shop computer and the chip in my 1st generation controller. Got the machine to jog with the Deskcnc software but never ran any code. A couple days ago I generated some code from a dxf file and found the m3 & M reversed....same with spindle button on the control panel. Click off turns spindle on ....click on turns spindle off.. I am using a USB to serial cable that was also replaced. Could this be swapping them codes????? I ran several codes today and everything seems to work fine except for the reversed m's Hope someone can offer a solution. I am running V 2.0.1.93--------- Also would like to know if the latest version 2.0.2.65 will work with my old controller. Gary Last edited by gld952; 12-07-2011 at 06:57 AM. |
| Two possiblilities I can think of. 1. The software configuration has been changed for the spindle from active hi to active lo action, which would reverse your spindle operation. 2. There is a normally open and normally closed contact on the relay driving your spindle and the wrong contact is being used. Matt |
1. Software version has not changed, and I can not find any place to change spindle config. 2.I'm using a solid state relay, and I replaced it with a new one. Didn't fix the problem. Thanks anyway Gary |
| I assume "chip in the first generation controller" is what the USB to serial cable is attached to? I'd guess the issue is there. I've no experience with your specific software. Yeah, an SSR does not have NO and NC contacts so that idea is no good. Have you talked to the manufacturer? You could work around it with a relay as I mentioned but that is not ideal as "default" for the relay would be spindle on. Matt |
| Additional info on this problem....When running a file.. M05 turns spindle on, but M03 will not turn it off..... but clicking off turns spindle on ....click on will turn spindle off. Have contacted the manufacture, but no responve yet. |
| Need Help!- G codes and M codes for Mazak Quick Turn T-2 | sauli | Mazak, Mitsubishi, Mazatrol | 0 | 05-23-2011 11:22 AM |
| X Reversed | mishawaka | Taig Mills & Lathes | 2 | 03-03-2011 09:28 AM |
| Need Help!- Need full list of G CODES AND M CODES FOR FANUC 21I | SonnyTees.com | G-Code Programing | 3 | 02-23-2010 10:27 AM |
| M-codes and G-codes 4 Matsuura ES-1000V | maximusek | G-Code Programing | 2 | 11-27-2007 06:41 AM |
