Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Carken Products (Deskam, DeskCNC etc)
Carken Products (Deskam, DeskCNC etc) Sub-Forums: Deskam, DeskCNC, DeskArt
Old 07-29-2010, 12:25 PM
southbendlathe is on a distinguished road
faulting out....help....please help
well i inhareted a sherline 5400 cnc mill and desk cnc from a friend who is fed up with it.......and i agree, what a pile of junk.......but maybey you guys can help me...
last nite i crashed it, had it running great for the last 2 1/2 weeks, then i over travled the y axis.......
today, the bloody thing faults out right after i start up a program, at first i thought it was the bob cad program i imported, so i uninstalled every thing, desk, bob cad every thing.....then i reinstalled just desk, same resault......machine jogs ok, then right after i hit go the z axis moves down the amount of - feed, and every thing stops, it dosent rapid down it feeds down the amount of z i told it to deep in to the work, then the controlar says its moving, but nothing, the sarvos go " limp" i.e. i can rotate the machine handles when its running......i did get one program to run for a min, then i stopped....
we have fought evey dumb problem from the get go, from bad service with im, to them building a junk control box.....
i dont know what to do..
machine specs are:
5400 sheline , sarvo cnc retro fit by im serv
globe motors
voltage 30.0
my set up specs are:
machine volocties :
accelerations 11500000
accel scale 18
max velocity 75000
statr velocity 7500
axes set up:
steps per in 112914.00
max vel (sps) 75000
does this help???
please some one...any one.......
Old 07-29-2010, 02:53 PM
awerby is on a distinguished road
Servos do worse in a crash than steppers
Stepper motors are perfectly content to come to rest against an immovable object; servos just keep trying harder until they die (or kill something upstream).
Try switching the leads from the Y axis (although technically that should be called X or Z on a lathe) to the other axis and see if the fault follows along. (Turn everything off first, and let the capacitors drain a bit). If it does, then you've probably fried the driver. If not, you likely killed the motor.
Andrew Werby
www.computersculpture.com
Old 07-29-2010, 04:09 PM
switching the leads ??
the power leads? the encoder leads? switch both? and what u call a driver, the board in the controlor?? because we just had these tested early this year......im told us they were just fine.........
Spindle faulting levelzero Tormach PCNC 19 07-16-2009 02:47 PM
Gecko Faulting and Mach3 lifestill Mach Mill 8 07-02-2009 12:34 AM
Problem- servos faulting out djtoolz Carken Products (Deskam, DeskCNC etc) 16 12-21-2008 06:07 PM
Gecko 320´s faulting irover Gecko Drives 4 07-15-2008 04:26 PM
Gecko's faulting dowling177 Gecko Drives 2 04-08-2005 02:02 PM
