| Canadian Club House A place for Canadian's to hang out. |
Does anyone know of a supplier for timing belts and gears in Ontario. I am trying to work out the drive system for my machine, the steppers i have may be a little light so I was figuring to gear them up about 4-5 / 1. |
| http://motiontek.ca/pulley.html haven't got anything from them.. i got mine from http://www.bbman.com/products/timing...t-pulleys.html one was defective and i had to send a few emails to convince them to replace it, other than that they were pretty good |
| motiontek is quite expensive, although it does look high quality. Not in canada, but just throwing them out there: www.smallparts.com has many items, pulleys are various plastic types https://sdp-si.com/eStore/ has tons, including metal or hubbard cnc on ebay has some well priced XL belts + metal pulleys The first two ship UPS (which can be scary for fees). I had good luck with smallparts for a $25 order, but haven't tried sdp. USPS would be slower but at most you pay taxes + $5. |
| Hi, for your pulleys and belts you can order by phone at sdp-si.com and they will send your order using USPS and it will cost you an additionnal 10.00 but at least you know the ending price and this is not so if you use UPS from what I can read you are looking for a 4.5:1 ratio, while going at spd-si web site take a look at their center distance designer http://www.sdp-si.com/Cd/default.htmto make sure that you have the proper number of teeth in tha swall pulley |
| Check with Toronto Gear, http://www.torontogear.com/ , they deal through distributors, probably most power tramsmission companies like Toronto Bearing, Canadian Bearing, etc. I've had reasonable success with their products and they can supply a fairly wide range of belts and pulleys. Custom parts are pricey but stock stuff is priced OK |
| check with Martin Gear www.martinsprocket.com they have a full line of timing gears there is also Mcmaster Carr www.mcmastercarr.com |
| You can email me at xzeroautomotion@live.com for belts and pulleys |
| Need Source - Timing Belts / Gears | rich | CNC Wire Foam Cutter Machines | 5 | 09-07-2006 09:14 AM |
| Timing belts, gears, source? and questions? | CuttersCov | DIY-CNC Router Table Machines | 5 | 03-22-2006 06:07 AM |
| Questions about timing belts & gears | rc-cellar | Mechanical Calculations/Engineering Design | 1 | 04-27-2005 11:09 PM |
| Timing belts, gears, and ratios | samualt | DIY-CNC Router Table Machines | 11 | 12-19-2003 07:09 PM |
