Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
Old 02-13-2009, 11:45 AM
RIFF-RAFF is on a distinguished road
Super Newb
Hi everyone,
My name is Frank,I live in Burlington Ontario.I'm as green as can be when it comes to machining.I have never used a milling machine or a metal lathe but always had an interest in it and never did anything about it till now.Anyhow,I just purchased a new CT129N milling machine from BusyBee and can use a ton of advice.For now,I just want to get to know my mill and learn how to use it and eventually I would like to convert it to CNC.
Can anyone direct me to a source or sources for learning material like DVD's,Tutorials,internet,books,etc on how to set up and use a mill.Also,information on what software is needed to run a CNC mill (mach 3?) and how to get started using it.Finally,sources of any step by step instruction on how to convert a manual mill to cnc,what parts will be needed, how to select the right parts for my mill and where to source them.Any recommendations will be much appreciated.Thanks everyone for reading and I hope my first post isn't too overwhelming.
Frank
Old 02-14-2009, 02:34 PM
dkirby is on a distinguished road
Hi Frank, My name is Dave Kirby, at one time I lived in Burlington and Waterdown but now I am in the Brantford area.
I am not trained as a machinist, since I am a mechanic, but I own a fair amount of machinery and am mostly self taught, I will try to answer some questions if I can.
I am not familiar with Busy Bee's mill so maybe you could inform us all as to what the spindle taper is and some other features of the machine, such as the table size and the travels of the x, y, and z axis's.
This may be a good starter machine for you but down the road as you find the limits of the machine you may find that an up grade to CNC may not be the best for what you have.
I was lucky in that I started with a lathe of fairly good quality,(Standard Modern) that I thought was too big for my intended purposes but turned out over the years to be just right for 75% of what I do, to being too small for the rest.
I also have an Elliott milling machine that I thought was overkill for my needs but after a few years is just right and comfortable for me to use.
I just purchased a Milltronics CNC machining center last week and I know absolutely nothing about CNC and that is why I am at CNC Zone now.
As far as reading material to try and learn from, there are some that I bought from Busy Bee and KBC Tools. For the first while I spent quite a bit of time at the library, but now I have a computer (another learning experience) and find information readily available. You may want to try going to The Homeshop Machinists web site as they have some forums there that are very informative and they publish machinists mags. for the hobbyists.
There will probably be someone who will come along later who is much more knowledgeable in what your looking for, but I am close by so if I can help I will.
Dave
Old 02-14-2009, 07:04 PM
Hi Dave,
Thanks for responding to my plea for help.The table size is 20"x7",x-11",y-7",z-15" and it uses an MT3 spindle.I purchased the mill and lathe that I have because it falls within my current budget (the weak economy is hurting me)and figured that they would be good enough for me to get started in my quest for knowledge.I fully expect to upgrade to bigger and better machines at some point in the future once I get a handle on things and I get my shop built.I'll check out the site you mentioned and keep you in mind if I have any other inquiries if that's okay.
I live immediately south of Clappison's Corners and the bottom of HWY 6.Thanks again.
Frank
Old 02-14-2009, 07:20 PM
trubleshtr is on a distinguished road
Hi Frank,
Have you tried "youtube" for video's...might get you thinking if you are a visual learner?
Here is one link that maybe of help?
http://www.youtube.com/results?searc...&oq=cnc+mill+s
I own the B1977 bench mill from busy bee...I have collected parts to cnc it one day. I also have a few other home-made cnc builds on the go...but now I am married with kids these days my free time for hobbies is nil...
I work in the industrial maintenance field...I build/repair cnc and automated equipment all day...and do my own service thing at night..
Feel free to ask away...I'll try to anwser anything I can...there are a lot of smart people on this forum.....you have come to the right place to ask questions...I would just be specific about what you want to know and post it...
I am up in Georgetown....
menomana
Old 02-14-2009, 07:58 PM
Small world Frank, my doctor is in Waterdown and when I lived there, it was on Parkside Dr. just up the hill from you. On Dec. 19. I had a Drs. appointment but was stranded at the bottom of Clappisons (snowstorm) probably not too far from your place.
With the spindle being a jacobs taper does it also have a drawbar to hold the tool holder tight?
Dave
Old 02-14-2009, 09:25 PM
Originally Posted by trubleshtr View Post
Hi Frank,
Hi trubleshtr,
Thanks for the ideas and yes,visual learning is good.I did spend a bit of time searching youtube,unfortunately though,its easy to get side tracked or drawn away from your original search there.Its also hard to find any sets of videos with any form of operational sequence.Thats why I would prefer text books or DVD's or even sites that are dedicated to teaching the art of machining.I will definitely check out your youtube link though.
I did see the B1976 and B1977 at BusyBee but they were too big to haul down to my basement.
Frank
Old 02-14-2009, 09:34 PM
Dave
Dave,the next time you get stuck,give me a scream and I'll drag you up the hill.I have a Diesel Dodge dually 4x4.
My mill does have a drawbar.I actually just finished setting up my mill on its stand about 10 minutes ago,plugged it in to try it out and Nada?!?Thats a bummer.
Frank
Old 02-14-2009, 10:08 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Frank. Welcome to the Zone!
See that plastic guard in front? Check to see if it contains a switch that does not allow mill operation unless it is in place.
CR.
Old 02-14-2009, 10:11 PM
Also check the big red Estop button to see if it has been pressed.
CR.
Old 02-14-2009, 10:32 PM
CR.
Hi CR,I figured it out.Turned out to be a faulty outlet.Someone removed the tab connecting the upper and lower half of the outlet.Thanks.
Frank
  #11   Ban this user!
Old 02-15-2009, 09:27 AM
Good! sounds like you are clear for chip-off.
Enjoy!
CR.
  #12   Ban this user!
Old 02-15-2009, 09:38 AM
Enjoy!
CR.
Actually,I only have 2 new end mills so far and need to get some other tooling like holders,a clamp kit,vise etc.......then I'll be clear for chip off.
Frank
newb here joshuaz2 CNCzone Club House 0 02-01-2009 10:45 PM
Newb still not getting it. Spinnetti Mastercam 24 03-26-2008 08:45 AM
Please help a newb hakachukai Mini Lathe 12 07-14-2007 10:49 PM
newb to cnc krymis Benchtop Machines 6 06-15-2006 02:23 AM
Newb to DIY CNC, any help tbcsoul DIY-CNC Router Table Machines 12 03-28-2004 08:10 AM
