Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
Old 05-07-2008, 04:37 AM
cci-mule is on a distinguished road
Question Biesseworks programing
using Biesseworks on a Rover B 7.40
I would like to speed up the program work time,
EXAMPLE:
Simply, if you run a bit down a 10ft board using 3 passes, it starts at one end rips down to the other end, lifts up, comes all the way back to the start point, lowers for pass #2, rips back down to the end, and repeats(pass#3).
Is there a way for it to run the first pass lower at the end and come back instead of going always from the start point.
it seems like just a time waste when we all know time=money,money money
thanks.
Old 08-16-2008, 04:18 PM
jeremy budgen is on a distinguished road
What i do is to create three individual programs of the same geometry and simply reverse the second ones direction opposite to the first and third.
You must first create the program and when you see the different programs on the left hand box dubble click the relavent sub program and check the reverse box, if you do not see it there then go to settings, milling data and look for the reverse possible box within the typical data field.
hope this helps
jeremy
Help with Biesseworks als12 Commercial CNC Wood Routers 36 03-24-2011 11:52 AM
0-M programing help please venomgrrrl Fanuc 22 12-08-2007 12:51 AM
Heidenhain programing help lazerracing Bridgeport and Hardinge Mills 4 12-04-2007 07:05 PM
CNC programing Fryzss General CNC (Mill and Lathe) Control Software (NC) 8 10-27-2007 11:33 AM
CAM programing kenlambert G-Code Programing 1 02-03-2006 01:03 AM
