Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
View Poll Results: How to adjust Z value so it doesn't cut above the material
HELP - Cutting from toolpath with rhino generated tool path 1 33.33%
HELP CNC running toolpath in the air 2 66.67%
Voters: 3. You may not vote on this poll
Old 03-19-2008, 09:23 PM
jerollie is on a distinguished road
Exclamation Please Help!3 Axis Milling-How to adjust Z value so it doesn't cut above the material
Hi I am in the process of learning milling in 3d on the school's 3 axis axyz cnc machine.
The model and tool path are generated in Rhino and imported to tool path.
Q: In toolpath output, what do I input for DEPTH ?
I have tried setting it as 0, 1 , etc. When I run it, the machine runs the tool path about the stock.
Please help me ! Greatly Appreciated !
Old 03-20-2008, 01:21 AM
toastydeath is on a distinguished road
In CAM, output the proper code. That is, have it go to the proper depth of cut as if you were really cutting metal. On the machine, edit the work coordinates (where you set up your XYZ on the part) and bump the Z wear offset up enough so that your deepest cut is up above the metal.
The Machinist's Chatroom
http://machinechat.freehostia.com/
Old 03-27-2008, 07:51 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
1st you need to know where the Z offset of your tool is set. I am assuming you or someone set the tools up when installing them in the machine, if not run away, because I guarantee you are going to crash the machine.
In CAM software you position your stock relative to it's position to Z zero in the real world. Now you can set your depth of cut and have it work.
EG if your cutter offset (on the machine) is set to zero on the table. and your part to be cut is an a vise - lets say the top of the part is 5" above the table.
If you have tool 5 in the spindle - then to position the tool exactly on the top of the part your code should be G0 G90 H5 Z5.0(H5 tells the control to use the height offset for T5(this may be what you are overlooking in RhinoCAM BTW)).
So to cut .5" deep in this part your Z height in the actual code will be 4.5".
It will take another 2 pages to explain the CAM setup, so you can check this stuff 1st and repost.
www.integratedmechanical.ca
Cutting G10 material without metal tools? (CNC milling) burnthills General Metalwork Discussion 5 11-01-2006 02:34 PM
material to practice milling xovationx General Material Machining Solutions 10 03-21-2006 10:54 AM
Milling Durastone material using CNC arazelan17 Glass, Plastic and Stone 6 03-18-2006 01:58 PM
Milling a very hard material arazelan17 General Metalwork Discussion 0 02-16-2006 12:09 AM
Pocket Milling - Less Material Natchamp Visual Mill 5 09-12-2005 09:21 AM
