Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
Old 01-08-2008, 12:28 AM
woodman08's Avatar
woodman08 is on a distinguished road
question about what bits to use
I need a bit of info about router bits.
The vcarve prg talks about end mills ,is an end mill an up spiral bit.
What bit should i use to cut solid wood panels ie oak or pine.
What bit should i use to cut particle core ,mdf plywood.
I feel a straight but with a bottom cutter carbide should be ok to cut through all of these just lower the feed rate
Bits teenrocketnerd DIY-CNC Router Table Machines 8 06-23-2007 11:30 PM
What bits to use becikeja WoodWorking 5 08-11-2006 11:27 AM
Where to buy bits hugo carradini DIY-CNC Router Table Machines 2 05-23-2006 07:52 AM
Luv those little bits.. CRFultz DIY-CNC Router Table Machines 27 05-14-2005 06:41 AM
Newbie question on drill bits ezland00 DIY-CNC Router Table Machines 4 02-27-2004 03:53 PM
