what is it ?
Does anybody use lollipop cutters for small undercuts? If so where do you buy them?
what is it ?
I think he means ball cutter? take a look through this guys router bits and see if you can see what it is you're looking for?
ghsu2ia3 | eBay
I grind my own. For my purposes, I start with a 3/8 bit, then lay out a .200" circle on it. I grind it so that I follow about 200 degrees of the contour. For aluminum, I also take a dremel tool to it and dish out the top surface to get a keen edge.
I order from here..
Harvey Tool - Find Undercutting Ball End Mills at Harvey Tool Today!
