It is wise to drill a pilot hole first so that the required size drilled hole does not waver off true.1- When I use a carbide drill do I or do I not use a center drill
The harder the steel the slower the drilling other wise if you go too fast it will wear out the drill/tool faster.
LinkBack URL
About LinkBacks
