Results 1 to 12 of 12
Thread: need some one to cut my machine
    Jun 2004
    Looking for someone local with a cnc router or laser cutter to cut out a diylilcnc for me
    I am in the Fraser valley
    But any where in Canada would be good
    I have called a few shops locally they want 700 or more
    To cut this they have told me it would be approx 300 minutes of machine time
    I have the drawings
    But they are free on diylilcnc.org
    Aug 2006
    canada
    did you get any one to cut out your machine, I,m in deroche BC, just east of mission.
    Jun 2004
    no I haven't been able to find anyone that will cut it for less than $700
    Aug 2006
    canada
    hey broncosis, I,m going to try and cut out the first page, but the only thing is exporting the svg file(ink scape) into a dfx file the size seems to change, do you know what the size of the pages are in inches ,. when changed it says the page is over 300" and I doubt that's the right size. If you know that would help. Graham
    Mar 2003
    Shelby Twp, MI....USA
    Why aren't you using the .dxf files they have on their site?
    Jun 2004
    the dxf files are for a laser cutter
    and a router needs a little more room
    I have also noted some issuses
    I will take one to work and see if I can get it printed on our large format printer
    Aug 2006
    canada
    Ok what I did was brought the laser cut dfx into my cad program then added a new layer then brought in the router cut dfx and scaled that to the laser cut. as long as the laser cut is the right size it should be cool. Graham
    Jun 2004
    Sounds good my converted drawings chime out super small
    Aug 2006
    canada
    Hey Broncosis, think you can find any dimensions for the drawing so to make sure we get it right.in inches preferably. The router cut files are in metric and a way off scale, it shows 9 meters for the first page, Graham
    Jun 2004
    well on the first page
    there are motor mount holes
    for a nema 23 motor
    1.856 inch square it is the top right part if your looking at the svg1 file
    Aug 2006
    canada
    HI, I cut out the y motor mount outer panel to see how it came out. the motor mount hole you are talking about should be 1.5 " which is the size the I cut out. every thing looks good, 1/4 " hole came out a 1/4". the whole part is 1.5"x3.87". so when ever your ready let me know and we'll get it done. Graham
    Feb 2012
    Quote Originally Posted by grahamshere View Post
    I just read thru this, and I wanted to congratulate you for your hard work on this, and to say you're an asset to the community.
    Doug Morency
    Kemptville, On
    1. Just IN- Water Jet Cutting Machine Sized for Machine Shops, Fabricators
      By Jetedge in forum Product and Manufacturer Announcements
      Last Post: 08-16-2011, 02:30 PM
    2. Replies: 0
      Last Post: 05-04-2011, 10:10 PM
    3. Replies: 1
      Last Post: 11-20-2009, 07:03 PM
    4. Deep Groove Taig machine would it be a good starter machine
      By Fritzie15 in forum Taig Mills & Lathes
      Last Post: 09-20-2007, 10:37 PM
