| Canadian Club House A place for Canadian's to hang out. |
I would like to know if I'm doing something wrong, because when I test me step motor the rpm is almost nill. The setup is as follows: 4 x Nema 23 Stepper Motor (57BYGH115-003) Step Angle: 1.8 Voltage: 6.3VDC Current: 3A Number of Leading wires: 4 Holding Torque: 425 oz-in http://www.wantmotor.com/ProductsView.a ... =75&sid=80 4 x Step Motor Driver DQ542MA Driving: 2 phase, 4 phase motor Current: 4.2A Micro steps: 128 http://www.wantmotor.com/ProductsView.a ... =75&sid=82 2 x Power Supply 350W, 48VDC (S-350-48) http://www.wantmotor.com/ProductsView.a ... =75&sid=90 The connections are as follows: Step Motor to Driver: Black Wire: A+ Green Wire: A- Red Wire: B+ Blue Wire: B- Driver to Power supply DC+ To DC+, DC- to DC- Driver to Planet-CNC 4 USB 4 Axis Driver has a jumper between DIR- and PUL- DIR- (PUL-) to GND on USB Board DIR+ (+5V) to S1 on USB Board PUL+ (+5V) to D1 on USB Board |
| I would hook it up as: DIR+ to D1 on USB board and PUL+ to S1 on USB board (my interpretation is that S1 is a Step output, while PUL+ is a Step input, and D1 is a Direction output while DIR+ is a Direction input). Also, do you have a load connected to the stepper motor? It does not look like you do, judging from the photograph. 128 microsteps is an extremely high value - is that the max value that the driver is capable of handling, or is that the setting that you are using? If you are using that setting it will take 25,600 pulses for a single revolution. Your computer might only be putting out 25,000 pulses per second, which would give you 1 revolution per second (or 60 rpm). Have you tried it with a smaller microstep setting, for example 1/8 microstepping? Are you running your motor power supplies in series to get 96 volts? |
| Hi guys just stubbled on this thread , when searching google about the exact Motors used here, my question is when i bought this kit he only sent me a 24V 17A power supply, now i havnt gotten to the test or install of the motors / electrics yet but what would a more powerful power supply do for me? I have exact same kit as Navop. Also thinking of getting the Gecko G540 to run these motors would 24V work for me or do i need bigger? Thanks Rgds Riche.. |
| Free MastercamX setup sheets for milling free 3 axis milling active designer setup sh | bigban | Mastercam | 1 | 07-26-2011 05:28 AM |
| ATC setup help | HLF Ordnance | Tormach PCNC | 0 | 07-14-2011 05:12 PM |
| Looking to buy my first CNC setup. Thoughts on this Partner III / Cent IV setup? | motoguy | Milltronics | 13 | 06-30-2011 09:34 AM |
| More setup help | binfordw | Benchtop Machines | 10 | 01-26-2010 12:27 PM |
| CNC setup | mwood3 | Benchtop Machines | 33 | 06-19-2008 07:22 AM |
