Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
Old 07-05-2010, 08:57 AM
jjackson's Avatar
jjackson is on a distinguished road
Linear Ball Bearings 1 inch diameter
I have an older wood cnc router I am trying to improve the performance for.
I need some one inch ID linear ball bearings, some open some closed.
Anyone found a reasonably priced supplier in canada?
John
Old 07-06-2010, 06:52 AM
cyclestart is on a distinguished road
XZeroautomotion in Toronto is (or at least was) clearing out 25mm supported rail. Excellent possibility he has blocks and NSK bearings in stock, you won't find better prices.
http://www.cnczone.com/forums/showpo...postcount=1168
Look up cnczone member gio666 for contact info
If you literally need 1" size he might not be much help, his stock is likely to be metric
Anyone who says "It only goes together one way" has no imagination.
Old 07-06-2010, 06:58 AM
jjackson's Avatar
That would be great except my router uses inch (25.4 mm) and not 25 mm.
Too bad!
John
Old 07-06-2010, 07:05 AM
Too bad!
John
LOL, I was editing to add that thought while you were posting. Bearings in inch sizes tend to cost a premium, must be economy of scale type of thing.
Old 07-06-2010, 08:13 AM
jjackson's Avatar
And to be 110% certain I re-checked and they are 25.4 mm not 25.
I know that 25mm or some other metric size would be more economical, and if I was building from scratch I would use a different size. The router was built around 1990 I believe. Built mostly from 1 X 3 inch aluminum stock it is very solid, but all that mass makes for lots of friction on the current bushing style bearings.
If there is an economical upgrade that would be cool, but at some point it becomes cheaper to put the router on Kijiji and start over.
John
Old 07-06-2010, 04:29 PM
kevin swan is on a distinguished road
try Applied .com looks like they have outlets near you . I have used them here for years
Old 05-25-2011, 03:55 PM
sockules is on a distinguished road
Hey, were you still looking for linear bearings? I have 20(ish) Thompson 1" ID linear ball bearings. I have 1" shafting from NB as well; honestly just never got around to using it. Bought it, then figured I'd try and use supported rail instead. Let me know!
Old 05-27-2011, 09:49 PM
jjackson's Avatar
I did buy some 1" ball bearings, but after installing them the problem was worse so I went back to bushings. I think my problem is that the ball screw and the rails are not perfectly parallel so when I get near the end of travel there is binding. At this point instead of spending much more to fix the problem I might upgrade to a larger machine.
Where are you located?
Thanks.
Old 05-27-2011, 09:54 PM
Yeah, if you're binding you're probably not parallel. Have a similar problem with an old Dore Westbury mill I converted to CNC, lost about half an inch on the Z axis because the leadscrew seems to be on a bit of an angle, or bent. I'm in the Brampton area, centre of the earth... Did you make the machine yourself?
Old 05-27-2011, 10:18 PM
jjackson's Avatar
I bought the machine from a high school, it was made around 1989. Appears to have been machined by CNC out of solid aluminum - no extrusions.
I will be going by Brampton in a few weeks on my way from Ottawa to Ann Arbor for the CNC Workshop by Digital Machinist.
I am also suspicious of the recirculating ball nut (right term?) on the ball screw. Makes a lot of noise when running. Know a good place to get them?
Attaching a shot of the gantry showing the bushings.
ID:	135073   Click image for larger version
  #11   Ban this user!
Old 05-27-2011, 10:24 PM
Do you keep the ballscrew and guides greased? Honestly, I usually look for stuff on e-bay, haha. Most recirculating ball bearings allow for some degree of angular variance, I don't imagine those bushings will. That's weird that the binding would be worse with the recirculating bearings. Have you tried disconnecting the plate that attaches the nut to the ballscrew and try moving the gantry lightly with your finger and feel for binding? You're probably right about the ballscrew being bent or misaligned. Have you considered swapping it out for a timing belt system?
  #12   Ban this user!
Old 05-28-2011, 10:15 AM
jjackson's Avatar
I keep a bit of dry spray lube on them, but no grease as this is a wood router that cuts mostly MDF - lots of "wood flour". Carriage moves freely with just bearings. I would not consider a timing belt on this machine - if I went to those lengths I would build a bigger one. 17 X19 inches working envelope is not huge for a wood router!
Replacing ball bearings on INA linear rails roger_e Vertical Mill, Lathe Project Log 2 02-05-2010 01:44 AM
Thomson linear ball bearings panozeng Linear and Rotary Motion 2 01-22-2007 07:19 PM
What size ball bearings for linear blocks? Zumba Linear and Rotary Motion 1 05-19-2006 12:22 PM
NSK Ball Screws and linear bearings? Burner DIY-CNC Router Table Machines 15 02-11-2006 10:44 AM
Inch Linear Bearings marchantdice Product Announcements & Manufacturer News 0 01-02-2006 04:19 PM
