| Canadian Club House A place for Canadian's to hang out. |
Hi, just would like to share with others the construction of my dedicated woodworking shop and since I'm a 25 years experience as a CNC machinist, my metal working shop. This is a 24 X 36 shop. This will be for my lathe, My 6X4 Aluminum CNC router and a futur CNC mill and all my woodworking equipments. Concrete will be poor this week, walls and trusses are due within 2 weeks. Hope the pictures will upload, had some problems with them. Will keep updating as soon as work progress. Jeff |
| You should cinder-block up the walls to about 40 inches, and then use a 2x8 sub-plate to cover the tops. This will give you 11'6" ceilings. Way better for woodworking (swinging large boards around) and dust collection systems, and lighting. Or not. I did, and I am way happy with it |
| pouring a real footing would have cost a lot more. The concrete slab is 5 inches thick and 12 inches thick for the first 2 feet around it so this is some kind of a footing. The concrete slab alone cost $5000.00 and concrete alone cost more than $3000.00. Plus the wire mesh, steel rod, thermo foild, 4 truck load of gravel, excavation, compacting, polishing. I need to keep money for the building, 24 X 36 is the dimension on a house so this is a lot of money, this is at least a $20000.00 to $25000.00 construction. Jeff |
| That's going to be a great shop. I'm jealous. So here's a dumb question. Aren't winters going to be an issue without a footing that extends below the frost line? In the north east US (where I am), I believe it's 3-4' minimum. I can imagine that the slab would float just fine, but won't the exterior walls be prone to movement without a deep footing? Or maybe you're some place where that isn't an issue... Steve Last edited by stevespo; 06-05-2010 at 12:07 AM. |
#10
| Well, in some places, the American work ethic is slacking, greed is more important that taking pride in your work, etc. Ha ha... I said some... I paid 3500 for my slab, to get 75% of what I was promised, and with amateur quality. 2 years later, I have cracks that extend from wall to wall. I found a shady mason to do my block work, too. Needless to say, the drain-tile, positioned around the base of the walls (slab is 2 feet underground at the back), was sealed at both ends with clay. I recently put in a sump pump (just in case), and let the water out of that drain tile by elaborating on the drainage system. Sorry if I sound bitter, but my faith in contractors is shot right now. I get better results doing things myself... even if it is my first time. Are you speaking of the frost line? I never knew that floating had anything to do with that. Would you mind elaborating? Rob |
| MXtras Shop Pics | mxtras | CNCzone Club House | 107 | 07-26-2011 06:13 PM |
| My futur Wood and metal Shop (Pics) | jeffrey001 | Canadian Club House | 1 | 05-28-2010 06:45 AM |
| Comments Needed-Wood vs. Metal in Garage shop | hsgreer | DIY-CNC Router Table Machines | 1 | 03-15-2008 01:07 PM |
| Pics of my metal cnc table (base w/rails complete) | guru_florida | DIY-CNC Router Table Machines | 7 | 12-14-2007 05:12 AM |
| Wood or metal | cncman2 | DIY-CNC Router Table Machines | 5 | 04-01-2003 07:17 AM |
