Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
Old 05-10-2010, 02:17 PM
lucky021 is on a distinguished road
May 10's question about output signal setup
I don't understand what the different is between Enable1-6 and Output #1-20 in the Ports and Pins configuration.
I tried the following setup,
click the Enable1 to make it enabled, and set the pin 1 on port#1 with Active High, the voltage on the pin 1 is 5V;
click the Output#1 to make it enabled, and set the pin 14 on port#1 with Active Low, the voltage onn the pin 14 is 5V;
How could be different Active low and high make the same 5V output on the pin?
And, what kind of usage we need the output for? For example, if I need to control the coolant, which one I should use/setup? or may I use one of them to control the spindle?
I am confused now, thank you
Newbie- 1.6V-3.0V random signal voltage parallel signal from output – Any advice? cjchands Mach Software (ArtSoft software) 0 11-12-2009 04:36 AM
Need Help!- ** (NEWBIE) How to activate assigned OUTPUT signal ** cjchands Mach Software (ArtSoft software) 3 09-19-2009 06:45 AM
Need Help!- Input/output signal on 0M-C padobranac Fanuc 3 10-28-2008 09:49 AM
No Output Signal tz1238 Machines running Mach Software 1 01-27-2008 02:57 PM
Diag: Output Signal: Enable 1 help... Flatline's Up! Syil Products 11 04-06-2007 02:11 AM
