| Canadian Club House A place for Canadian's to hang out. |
now, I need 6 inputs for the limit switches (X++,X--,Y++,Y--,Z++,Z--), but there is only 5 inputs on my breakout board, what should I do? To buy a second breakout board and use the second parallel port? or may I use all these 6 limit switches to setup on the same pin, say, pin 12? It seems OK since all limit switch will trigger the E-stop. Am I correct? thanks |
| If they are normally closed, wire in series. Normally open, wire in parallel. NC is preferable if you have both terminals. http://www.plasma777.com/driver/xylo...cnc_plasma.htm |
| Yes.
Thanks for that confirmation. My driver board also has the capability to take inputs from the limit switches (though, just one input each for the pair of ++ and -- limit switches). I was wondering if I should also try to wire in the limit switches to the driver board as well, or if providing the switch inputs to Mach3 would be better/sufficient. |
| If you wire the limit switches to the driver board, you might have a problem jogging back off the switch. Mach3 has an override to let you do this, but if the switch disables the driver board how are you going to move away? Wilfrid |
| I found this wiring diagram, which was mentioned in another thread, that looks to be helpful. Maybe it will help the OP as well. http://pminmo.com/PMinMOwiki/index.p...limit_switches |
| plutp-P board encoder inputs | visky | LinuxCNC (formerly EMC2) | 2 | 04-23-2010 01:44 PM |
| C10 breakout board | csmoak25 | Automation Technology Products | 4 | 03-19-2010 12:16 AM |
| which breakout board | daisydog | Controller & Computer Solutions | 2 | 06-22-2009 08:11 AM |
| Breakout board, Relays on board? | Cooper | Open Source Controller Boards | 11 | 06-09-2007 07:55 PM |
| Breakout Board | bkkpool | General Electronics Discussion | 2 | 07-28-2006 01:15 PM |
