Originally Posted by
Marc N Fournier
Where did you learn how to read.. or do you have some type of reading difficiency.
Did you notice he ran his demo on his laptop.. geee.. I run mine on a laptop also.. Geeee.. Major Geee hey....
He said he replaced the chips on the MM160, you know the TB6560 chips from Toshiba. Oh I forgot it took you how much time to figure that part out...
He has a bunch of TB6560 chips on hand. He said so about 15 posts back. If you read more carefully and stopped blabering how good you are you might learn something.
Browsed your web site. Must say you are good at the cut and paste from Wikipedia and other sources. At least if you changed some words so it was not so easy to trace back.
So if you want to continue on with your monologue, go right ahead... Or bettre yet, shut up and go play in the sand box with the other kids your age. Maybe they will be impressed with your vast knowledge of cat poop.
I'd love to get us both thrown out of here.
You would not be of great loss to the community at large.
Go fix your MILL.. Oh by the way that is not a MILL it is the most ugliest table I have ever seen with a computer and screen.. Where did you hide the mill. Or is it suppose to be that gathering of plumbers left overs you call a lathe.
Had you been polite, in the broadest sense of the word, you might have had merrit. But you elected to be pompous and as subtle as cow pie. Most of what you posted is crap and showed you know very little on the subject but have one big mouth.
I do not need you. I need you like a hole in the head. You need people like us to show you the way and correct you when you fall out of the tree but can't figure out which one you fell out of.
Should I go on or do you catch the jist of the message... Judging by your reading skills I probably lost you on the third line.. if you got that far..
So long you major ass from BC. if you'r ever in Quebec... drive strait thru to the other ocean and leap off the edge. Maybe you will discover the world is not flat after all, it was just your brain all along.
