| Canadian Club House A place for Canadian's to hang out. |
Hello from B.C, I am using three of these stepper motors on my benchtop cnc plasma cutter: Frame Size: NEMA23 Step Angle: 1.8 degree Voltage: 3.6V Current: 2.0A/phase Resistance: 1.8Ohm/phase Inductance: 2.5mH/phase Holding torque: 9.0Kg-cm 125 oz-in Rotor inertia: 300g-cm2 Detent torque: 0.4kg-cm Number of wire leads: 6 (See color code diagram) Weight: 1.54lb (0.7kg) Length: 2.21” (56mm) I am now in the works on getting a power supply, but i am not to sure on what size I should get. I have either been looking at a 24v 14 amp power supply or a 36v 10amp power supply. I am leaning toward the high volt low amp power supply do to that this is a plasma cutter since I want high speed and there is low torque on the machine. any suggestions would be appreciated. Thanks
__________________ Rob C Mechanical Designer/ Welder Fabricator. |
| I wasn't sure what voltage to go with when doing my CNC router with Nema23s. I ended up getting one of these http://cgi.ebay.ca/Cnc-Servo-Stepper...item4aa020f327 Output: 12V-40A, 24V-20A, 36V-13.3A, 48V-10A Can adjust form 0v to 48v And I'm glad I did. Set at 48v my steppers (380oz) were getting awfully hot. like 70*C plus. So I just dialed it back to 35v and it is working great
__________________ JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router Joes 4x4 R&P in progress |
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 05:13 AM |
| Need Help!- Which Power Supply? | jaru-eri | DIY-CNC Router Table Machines | 1 | 04-07-2009 11:15 AM |
| Power supply KL-150-24 24V/6.3A | PCcruncher | Automation Technology Products | 5 | 04-04-2009 01:32 PM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 02:56 PM |
