| Canadian Club House A place for Canadian's to hang out. |
Hi all... I'm going to be building a small CNC whileI'm waiting for my "Actual Machine" to be built.... so I've been shopping ebay for complete kits... So I need to know which of these motors are better Nema 11 or Nema 23 ( or should I stay awat from both. AND do these kits include all I need eletronics wise? Thanks In advance Imac Kit 1 4 AIXS CNC PC CONTROL COMPLETE KIT ! What’s in box? 1 x TB6560Stepper Motor Driver 4 x new Nema11 Stepper motors 28mm 11HY5401-20 1 x new powersupply 100W/24V 1 x Cable 1 x CD software(English Manual & Mach 3) MOTOR SPEC Stepper Motor Part No.: 11HY5401-20 Frame Size: NEMA11 Step Angle: 1.8 degree Voltage: 6.2V Current: 0.67A/phase Resistance: 9.2Ohm/phase Inductance: 7.2mH/phase Holding torque: 1200g-cm 17oz-in Rotor inertia: 18 g-cm2 Detent torque: 0.2 kg-cm Number of wire leads: 4 Weight: 0.2 kg Length: 51mm KIT 2 4 AIXS CNC PC CONTROL COMPLETE KIT ! What’s in box? 1 x 4 Aixs TB6560Stepper Motor Driver 290 Oz 4 x new Nema23 Stepper motors 57mm 23HS8610 1 x powersupply 200W/24V 1 x Cable 1 x CD software(English Manual & Mach 3) MOTOR SPEC Stepper Motor Part No.: 23HS8610 Frame Size: NEMA23 Step Angle: 1.8 degree Voltage: 8.6V Current: 1A/phase Resistance: 8.6Ohm/phase Inductance: 18mH/phase Holding torque: 14.5Kg-cm 207oz-in with unipolar(for bipolar,290oz-in) Rotor inertia: 18 g-cm2 Detent torque: 0.2 kg-cm Number of wire leads: 4 Weight: 1kg Length: 78mm |
| How small will your "small machine" be, and what kind of "actual machine" you are getting. Are you going to be building your actual machine? or ordering something premade.
__________________ JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router Joes 4x4 R&P in progress |
| Hi Dustin, The machine I am buying is from Zenbot... I'm in contact with Shaun there, nice guy, they are going to modify their 1624 machine to have a cut length of 48". The machine I plan on building is smaller, it will have a work area of around 14" X 20" "6" ( need extra height for ABS Extruder option ) I may be building this with the option to install an ABS extruder unit and run it using diffrent software so it can be used as a 3D printer as well similar to a "Reprap" unit. So I'm hoping the pkg(s) in my original post will do what I need. Hope this helps Imacman |
| Definitely go with the Nema 23s then. That way your electronics for your 2 machines will be interchangeable which could be nice for troubleshooting. Building the small unit would be much easier after you have the big machine, but should be easy enough by hand too.
I was wondering which kit you ended up buying. Did you get the Nema23 kit. I bought this same kit and had a lot of trouble getting things to work. I am new to Mach3, so configuration was difficult. I am looking for some help thouogh. I have the motors running now, but can't get them above a feed rate of 15. I have acme 10tpi on x, and 12 thpi on y&z. All are single start. I have the resolution set to 4000, and 4800, with the velecity of 15 and acceleration of 4, I don't know what the pulse numbers mean, so I left them both at 0. This is the only way I can get things to work, If I raise the velecity and try and run at a high feed rate, the motors have no torque. I can stop them with my fingers, or if too high, then they don't even spin. If I raise the velocity to high, the I can't even use the continuous jog, only the step jog mode. I have the board set to 25% current, (50% does the same) 1/2 microstep, fast decay (don't know what this is either). So my question would be, it there a way to get a higher feed rate without rebuilding my machine and changing the acme rod. Any help would be greatly appriciated. |
| Need Help!- Stepper motor advice!!! | Drewbob | DIY-CNC Router Table Machines | 2 | 10-25-2010 12:43 AM |
| DC Motor Swap Advice | 2_many_hobbies | Taig Mills & Lathes | 12 | 02-14-2009 12:45 PM |
| Need motor advice for a project... | kentrob11 | General Electronics Discussion | 0 | 03-21-2008 09:05 AM |
| New motor and VFD, need advice | bilinghm | Phase Converters and VFD | 23 | 04-11-2007 11:20 PM |
| Router Motor Advice Please | Moondog | DIY-CNC Router Table Machines | 2 | 11-03-2004 01:49 PM |
