Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Canadian Club House
Canadian Club House A place for Canadian's to hang out.
Old 04-07-2010, 07:31 PM
Scotty27 is on a distinguished road
Post Leadwell LTC-15 Belt Replacement
Hello all i need some help . I am working on a Leadwell ltc-15 lathe and the drive belt has sheared off all the teeth. The belt is original, is there an easy way to put on the new belt ? With out removing the bearing housing and lower drive shaft ?
This belt is about 5 cm width ( 720 8m )the lower belt not the one going up to the spindle shaft .
Need Help!- BP Series 1, was BOSS 5, need help tracking down BEARING and BELT replacement bbuonomo Bridgeport and Hardinge Mills 7 10-14-2008 09:20 PM
Need Help!- I'm trying to find a replacement belt for my lathe ryansuperbee Mini Lathe 2 08-27-2008 06:47 PM
Belt Replacement vari speed jlv3901 Bridgeport and Hardinge Mills 3 07-24-2007 07:25 AM
Belt size/spec for Sieg X3 driving belt rashid11 X3/SX3/G0619/G0463 0 02-10-2007 07:01 AM
Lead screw lube amount. servo belt replacement bob1112 Linear and Rotary Motion 2 11-24-2006 06:59 PM
