New Here HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 24 of 24
Thread: HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP
  1. #13
    Feb 2018
    Default Re: HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP
    I was checking the Electrical Requirements again.
    SMM shows 3 Phase - 40A BUT there is NO * beside it stating that No Single Phase is Available.
    On the Mini Mill it shows Triple & Single Phase Amperage.
    I was told that running SMM on Single is possible but performance is reduced by 35%-50%
    Looks like i may be SOL on this without Phase converter! There goes anther $5K!
    Attached Thumbnails Attached Thumbnails HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP-smm-jpg
  2. #14
    Gold Member
    Jan 2005
    Quote Originally Posted by CCF_CUSTOMS View Post
    The spindle is double the Kw of the mini mill, you should look at a Phase Perfect converter, they are more expensive but are your best choice for clean efficient 3ph power
    Mactec54
  3. #15
    Feb 2018
    Locally here there is
    AMERICAN ROTARY
    PHASE QUEST
    These guys any good?
    They recommend their 40hp model. But fo say can operate off 30HP unit also.
    American say 98% efficiency.
  4. #16
    Gold Member
    Jan 2005
    AMERICAN ROTARY
    PHASE QUEST
    And that is total Bs 98% try about 40% if that, the only company that could claim that is Phase Perfect, you will never get that with a RPC
    Mactec54
  5. #17
    Feb 2018
    Does Phase Perfect have a location in Toronto? Also if RPC are not that efficient then does that mean Phase Perfect is a Static Converter?
    I'm pretty ignorant to these things so I'm trying to learn as quickly as possible. Lol. I have a machine sitting last 3 weeks that I can't use yet.
    Thanks!
  6. #18
    Feb 2018
    I called the Phase Perfrct Distributor here for Ontario. They told me a 20hp unit is good for the 15hp machine.
    They sent me specs I have to review tonight.
    Since you have one can you give me some feed back from your experience.
    The cost is approx $7,600cad after tax. Double the price of a RPC.
    Also, where are u located? Canada or states?
    Thanks!
  7. #19
    Gold Member
    Jan 2005
    Thanks!
    I did not say I had one, but I do have one and yes they cost around $7,500, for that size, yes they have no moving parts if that is what you mean, they do have 2 fans to keep them cool, but are not what is called a static converter, I'm in the USA
    Mactec54
  8. #20
    Dec 2003
    Its was wired correctly, The Colors were just swapped. at all time the hot was only on outside and center was a dead line.
    The Supply to the machine comes from a Single Phase supply The Neutral is not going to anything. it is a deadline.
    Only outsides Hot, 125V & 125V.
    Spindle is 15k rpm, 15HP. it is the Upgraded Option.
    Incidentally many 3ph NFB's (Non-Fused Breakers) need to see current through all three phase connections, therefore it is common industrial practice to loop one of the hot (L1 or L2) back through from the outer to centre connection when using it for 1ph .
    Also if using the Phase Perfect I would ensure that any non 3ph loads, i,e, single phase transformers etc, are fed off of the 2phases derived from L1, L2 and not the generated phase.
    Attached Thumbnails Attached Thumbnails HAAS SUPER MINI MILL 2004 - SINGLE PHASE HELP-phase-perf-jpg
    Feb 2018
    Quote Originally Posted by Al_The_Man View Post
    Hey Al, thanks for replying.
    I have my supply coming in to a splitter box. From there it feeds a 1 phase compressor and the second out put would feed the Phase Perfect unit. The Phase Perfect would only be used to power the 15hp CNC. Nothing else.
    In your opinion is a Digital unit like Phase Perfect worth the cost compared to a RPC like American Rotary. It's a big additional cost that I was not expecting but don't want issues either.
    Thanks.
  10. #22
    Dec 2003
    The Phase Perfect is obviously the better choice, it retains much more balance on the generated phase compared to VFD which can in some cases drop voltage on load.
    Although for RPC's I only have experience building and tuning them, not the off the shelf versions.
    The single phase loads I refered to would be in the control cabinet, motion controller etc , not external ones.
    Incidentally what is the nature of the 3ph loads, if only for the spindle, some have used a standard VFD for this and fed the rest from the 240v 1 phase.
    Gold Member
    Jan 2005
    Not in this case the Hp is to large on this machine for a Single phase connection
    Mactec54
  12. #24
    Gold Member
    Jan 2005
    Thanks.
    Night and day better, some machining centers don't like the RPC even the CNC rated units, you should talk to Haas as they do this all the time, they will give you the best answer, as to what to use
    Mactec54
