- Problem: Signal Generator
Hey fellow Canucks. I'm looking to connect with someone from Ontario that might have purchased a machine from Gorilla CNC before they went out of business. The problem I am having is with the signal generator. I have had endless problems with the sig-gen not receiving the signal. I have tried updating drivers, reinstalling, tried two other PC's with fresh installs, replaced the cables, and pretty much anything else that could be causing the problem. Flashcut hasn't been much help. I was hoping to find someone with the same signal generator to do one of two things. Try mine on your machine or try yours on mine. I just need to rule out whether it is actually the sig-gen before spending another $500 USD or so. Alternately, I'm looking for suggestions as to what I could use instead of the Flashcut. Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
