Source of HDF
Results 1 to 3 of 3
Thread: Source of HDF
    Aug 2015
    Default Source of HDF
    Hi Gang,
    I am from the Edmonton area and was wondering if anyone knows a source of High Density Fibre board. I am going to make a grid based vacuum table for my CNC and am under the impression that MDF is too porous for this purpose.
    Thanks in advance.
    Dan
    Registered Rooski's Avatar
    Oct 2013
    Default Re: Source of HDF
    Hi Dan, don't know if you've found an answer but I have some info for you.
    Upper Canada Forest Products
    15832 142nd Street
    Edmonton, Alberta
    Canada T6V 1H9
    t: 1 866 265 0624 | 1 780 863 3316
    f: 1 780 457 6638
    sales_edmonton@ucfp.com
    I have a 5 x 10 router table with a vacuum top in the same grid formation. It works great. Although I have it zoned, I can still hold small/medium/large work pieces in place on top of a full 4 x 8 spoilboard without clamping. The vacuum sucks right through my spoilboard. My base is made from UCFP's Medite MDF at 1.5" thick. I had to ensure my vacuum piping was sealed well and the grid patterns were well sealed with a spray sealant (used laquer clearcoat over primer)
    Spoilboard is 1/4" thick standard mdf.
    I think that UCFP may offer HDF sheets as well if you really are intent on going that direction.
    Oct 2013
    Also, I use a 1/2hp regen vac made by GAST. It is 32 to 39 Hg
Source of HDF
Source of HDF
