Depends on the make/type of drives,
In the general sense, servo's are the better choice.
Good day All
New here.
First post- I have started collecting parts to build myself a CNC router and to see how far I can get with out having to punchers anything,
So far I have built a 2'x4' stand 3' high from some old shelf unit and a desktop. I have 4- ball screws 4' long with nuts and taper bearings.
1"dia x40" long hard steel shaft but on linear bearings yet, some 3/4" linear bearings and shaft, Some 80-20 extrusion and some other type of box extrusion not quite the same size, My problem is I have access to a number of new scrap servo drives and servo motors but no control equipment
Do I use the servo equipment or try and trade it for stepper motors and drives which seem easier to use.
Any help advise or comments most welcome.
Thanks Ian.
In Halton On
The Drives I have are Delta ASD-A0421-AB 240v 400w and TECO Electro TSDA 20B-CC401G27F
240v 400w I also have a number of matching motors some with 10-1 gearboxes.
If any one is interested in purchasing any of these items please contact myself ianschofield@Hotmail.com
In theory servos are the better choice if you can afford them. I have a stepper cnc mill (Novakon torus pro). The steppers are reliable and fast enough for my needs. If you are on any sort of a budget just get the steppers. You can always upgrade later if you feel a need to.
Tom
