Place to order CNC parts in Canada
Results 1 to 11 of 11
Thread: Place to order CNC parts in Canada
    Feb 2007
    Default Place to order CNC parts in Canada
    Ethernet Smoothsteppers and Mach3 Software. Shipped from Alberta DashX - Products: SmoothStepper Ethernet
    400 Watt AC Servo Motor with Drive for 348.00US Shipped from BC Canada from DMM Tech DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    And there is other parts these company's have besides.
    Feb 2007
    Default Re: Place to order CNC parts in Canada
    If you are looking for 8020 extruded Aluminum You can order it from these places in southern Ontario
    CPI Automation Ltd.
    5155 Timberlea Blvd
    Mississauga, ON L4W 2S3
    Phone: 905-625-4805
    Fax: 905-629-8409
    E-Mail: jeff@cpiautomation.com
    URL: CPI Automation Ltd - Hydraulics, Pneumatics, and Control
    IPEC Industrial Controls
    17-109 Fernstaff Court
    Concord, ON L4K 3M1
    Phone: 866-665-7877
    Fax: 905-738-6251
    E-Mail: sales@ipecautomation.com
    URL: IPEC Factory Automation that is Affordable and Safe Home Page
    Feb 2007
    For Electronic part there is Digi-key and with free delivery on orders over $200.00
    All prices in Canadian dollars and include duty and brokerage fees.
    1-800-344-4539 • Electronic Components Distributor | DigiKey Electronics | Canada Home Page • 218-681-6674 • Fax: 218-681-3380
    Member mactec54's Avatar
    Jan 2005
    cybot
    You can also get a lot of parts, & routers form Xzero cnc
    XZero CNC Toronto Ontario Canada
    info@xzerocnc.com
    XZero CNC Routers
    PH 647-717-2487
    Mactec54
    Feb 2007
    cybot
    info@xzerocnc.com
    XZero CNC Routers
    PH 647-717-2487
    I looked the site over and cannot fine the lists of parts?
    I made this for a place for people to put links to parts sites I didn't really mean finished Cnc's Just parts sites
    If anyone has just Parts sites Like Power Supply's, Servo drives, Stepper drives, Breakout boards, Limit switches, Electrical panels and panel switches
    Please put the like in for others.
    This place is a little on the expensive side Motiontek | CNC Plasma Controller KIT | AC Servo Motor | Timing Pulley | Vacuum Pump and more and it does sell full Machines but there is parts list too so your not stuck buying something someone else made. What fun is that?
    Jan 2005
    Quote Originally Posted by cybot View Post
    Did you contact him before you posted this, obviously not
    Xzero sells every parts you want for routers/machine builds, may not be on his site yet, contact him for a list, spindles, ballscrews, linear rails, steper motors, drives, custom extrusions, table tops & much more
    Mactec54
  7. #7
    Jul 2005
    I have recently come across this site: SNB Aluminum - Online Store - SNB Aluminum Solutions
    They advertise on Kijiji, which is where I found them. No experience with them, but some of the parts look interesting.
  8. #8
    Feb 2007
    Yes that is a good place for 20mm linear rails for $159.00 59 inches long with 2 trucks. So for 300+ you can build a 50" high quality X-Axis and for a hundred Dollars more you can get 25mm rails and trucks. You can get the legs for a starter kit for a plasma or router $500.00 and add to it from other open sources.
  9. #9
    Jul 2012
    Hey guys,
    Can you suggest a good place that I can order CNC router bits from within canada. I am particularly looking for a flycutter with inserts to perform nice surfacing finishing/spoilerboards. I found some nice stuff at todaystools but this is based in the USA.
    Any direction here would be greatly appreciated.
    Cheers
  10. #10
    Member 2ferrous's Avatar
    Jul 2010
    Have you tried Busy Bee Tools?
    Dyna Mechtronics DM4400, HAAS VF-0E, HAAS Mini Mill
  11. #11
    Dec 2003
    Princess Auto sell wire, tie wraps, Push buttons and some relays etc, cheap.
