This can also be cut in 1/4" 6061 aluminum on water jet
Hello everyone, I'm in need of a quote for a straight forward cnc plasma table cutting job. please see attached the DXF of my parts. I will also insert an image for hole placement, because sometimes when I send a dxf the hole don't come with the drawing so I put crosshairs at the hole location and give a image for hole sizes. This needs to be made in either 3/16" or 1/4" steel i would rather have the 1/4". I hope this works. I see I forgot a crosshair on the smaller part that hole is centered on the 4 hole the hole needs to be 3/4" thanks.
-2 parts of each drawing. may lead to more
Thanks to everyone,
Mike
Mike,
I tried responding to your message but your inbox is full, please email me when you have the time.
There are no dimensions?
I suppose I could scale your picture but i don't feel like it.
Do you feel like providing some overalls?
www.integratedmechanical.ca
Well it's happened. I got parts machine from one of the replies here in my post (nextdaycnc) and they turned out awesome. But now the second set of parts I think he took my $$$$ and screwed me. I paid on Apr 15 and haven't even seen a reply to emails I've sent him there's been no contacted from them at all. That figures my last set of parts to finish my machine and the last of the $$$ funds to put this new machine together. Now it's gone and machine not finished, I don't know what the hell I'll do now All these years doing business on line and now I get screwed. Maybe someone knows the business and can help me out.
where abouts you located?
Ontario Canada about 1 hour north of Toronto
well if you were on my side of Canada, I might think about showing you that dealing locally and supporting local business can have benefits. Too bad.....
I did try keeping it local, and I wanted to keep local, but everyone I got quotes from where crazy expensive. I paid $425, here they wanted closer to $700 mark. Why guys have to charge so much is beyond me, that's why sometimes company's do the hole china switch you know. Right or wrong that's what is happening. Like I said above I wanted to keep local, as I was on a tight budget. Anyways thanks anyways.
