Is there someone that have proper equippment to do small steel pinion, in metric modulus M1.0 in the range of 13T to 20T with some particular threaded hub...... I need a small quantity of each size. Thanks. Martin.Similar Threads: calculatiing pinion size for rack and pinion setup Aluminium Products (Fishing) Machining( China CNC Machining )---www.inhacnc.comNeed Help!- dual pinion rack and pinion anti backlash Rack and Pinion- rack tensioned to pinion? MIS CNC Machining and tooling - General machining - Thermoform Molds
Forum Rules
