Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 04-06-2005, 06:26 PM
murphy625 is on a distinguished road
How to close LISTSETUP progamatically ?
I am using a list setup command that works fine but I have found that if its left open, processing of commands pauses. (not a problem)
But if a user leaves it open and walks away, this could be a problem.
I tried using the timer.fil to count down a variable and close it that way but it didn't work.
I put this in my timer.fil
!\19={\19-1}
I put this in m Mcode.fil
!\19=5
!LISTSETUP XXX;XXX;XXX;XXX :LISTADD EXIT :LISTADD ST1 :LISTADD ST2
!LISTPICK \21
!IF \21=EXIT THEN EXIT
!IF \21=ST1 THEN bla bla bla
!IF \21=ST2 THEN bla bla bla
!IF \19<0 THEN \21=EXIT :EXIT
----M1
I tried many other variants and nothing seems to close the list. Any ideas?
Should I say Thank You AL in advance???
Murphy
Old 04-06-2005, 06:36 PM
got it...
LOL
Sometimes the easy answers are the hardest to find..
!IF \18<0 THEN LISTSETUP :EXIT
thanks anyhow!!!
UPDATE:
I thought it worked but it didnt. All that code did was make the box very small and hide it behind a button on the screen at 0;0 position.
Any ideas?
close up of casting skippy Casting Metals 14 01-25-2007 07:05 AM
Looking For Someone close to London So We Can Build A Cnc Each chris69randy Europe Club House 2 05-09-2005 04:38 AM
ListSetup problem.. murphy625 CamSoft Products 1 04-01-2005 02:25 AM
How close can I space THK rails? bgolash DIY-CNC Router Table Machines 7 12-31-2004 12:13 AM
