Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 04-06-2005, 03:36 AM
murphy625 is on a distinguished road
Testing for drive enable?
Short of running a wire from my Galil ICM2900 EnableX pin to an input and then testing the input for 1 or 0, is there a way to test to see if the galil card has the X axis enable=true or false?
I know there is a command to test for Moving, but I just want to know if the enable circuit is true or false without using an input. I dont care if its moving or not..
Murphy
Old 04-06-2005, 10:52 AM
Al_The_Man's Avatar
I assume you want to record when the AEN is activated by the MO motor off command?
If so, if you look in the command Summary for Galil, the MO command can be interogated
e.g. Var=_MOX , this will record the status of the X axis off command in Var(iable).
Al
Old 04-06-2005, 11:42 AM
camsoft is on a distinguished road
Murphy,
Answers to a few question from today.
(1) WAITUNTIL #19=1 '#19 is an output
Since #19 is an output, you can:
(a) Click on the #19 relay light on the Digital I/O panel to change states
(b) Use the FAKE command
(c) Type #19=1 in Diagnostic
(d) Hit Esc
(2) Amp Enable.
Al is correct here. We would also say the input is important to react to since the amp itself may be in distress or over heated.
(3) If you're using the default Jogging then this has 'plug and play" jog features by default. You can customize this using the JOG.FIL file but it will work without any customization.
Tech Support
CamSoft Corp.
(951) 674-8100
support@camsoftcorp.com
www.cnccontrols.com
Old 04-06-2005, 02:55 PM
Originally Posted by camsoft
Murphy,
(d) Hit Esc
(2) Amp Enable.
(a) is not an option because that panel wont be open during normal run and the machine needs to break-out by itself.
(b). This is interesting.. FAKE I search the help files and got nothing on this one. Never even heard of it.. I dont have the paper manual with me, but I dont recall seeing it in there either.
(c) goes back to (a) so it wont work.
(d) Doesnt Esc end program?? We dont want to do that either.. I just want to break out of the wait..
I think if there is no way to break out of it then I am going to replace the WAITUNTIL with a GOTO LOOP code. (at least I can break out of that easy)
(2) Al is correct here.. (YES Al is like that often!)
Thanks for the advice! You folks are a big big help!!!
Murphy
Old 04-06-2005, 02:58 PM
Al
Yes.. That's it.. Thank you AGAIN Al...
I am obviously not very familiar with the galil commands. The SH and MO commands you taught me have really made things easier!!!
Can I say thanks again??? LOL
Murphy
Old 04-06-2005, 05:04 PM
FIXED IT !!!
I used a loop command and just checked a variable then :EXIT if true.
Thanks,
Murphy
Testing stepper motors monkeypuzzle Stepper Motors and Drives 5 07-19-2010 10:53 AM
Enable connections on drivers metalhacker Stepper Motors and Drives 6 06-12-2005 02:43 AM
Enable = False while doing other stuff? murphy625 CamSoft Products 7 03-30-2005 01:48 PM
Connecting Amp Enable keithorr CamSoft Products 5 03-21-2005 06:31 PM
Active High/Active Low Sanghera General Electronics Discussion 21 11-06-2004 09:47 PM
