| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
Hi all, I've got a Shizuoka AN-S and have torn off the Bandit (thank Grid) and reused the servo motors, put quality encoders on it and have Camsoft Plus driving a Gallil card (new from Camsoft). It's the 3 Axis card with the ICM2900. The symptoms are. 1. When doing the job I have a CNC spin indexer turning a part. When it indexes, a slitting saw does an X into the part, then a slower Y to finish the cut, then reposition and index for the next cut. When it does the Y it goes fine then lurches on the last 5 or 10 thou...(like a sprint to the finish line) 2. This axis has me tweaking the AMC drives all the time because occasionally the Y will jitter rapidly, oscillating around the finish line by about 2 to 4 thou....I adjust the feedback and current limit to fix but it has always come back. When running a program and it does this the program will stop after timing out not having reached the target position. I have No problems with the X or Z which are wired the same way (cable routing, etc.) and the same idiot (ME) did the servo tuning. I'm running the machine since I have to make parts and have to live with it until the backorders are controlled. Any thoughts? Thanks,
__________________ i build the braces that keep american teeth straight......tick tick tick |
| What I'd try: I suspect this may be coming from the TOLERANCE, BLEND, or <one other command that I forget right now> in Camsoft. To verify, I'd go native Galil and command some low speed moves. If the problem is still present, its in the servo tuning most likely. If not, look to the above issues. Karl |
| Hey, Karl, Did you think of the other command which coould do it? BLEND I don't use and TOLERANCE has no effect. Keep 'em Flying Nelson
| But, its time for you to contact the wizards at Camsoft on this one. Karl |
| Well, Karl I haven't had much success with that route so I changed the startup.fil POSERROR parameter and - with crossed fingers - I may have gotten it.Damn strange though, I changed the value from .003 to .0001 for squats and giggles, and it stopped....I had been observing a test routing I did and it literally jumped .020 to the target position (no sense) I have a pile of broken .012 carbide slitting saws in my trash can...$60 a pop. I hope I got it. BTW what do you do? automation machinery? Thanks again, (and again) Nelson
| NelZ What kind of gearing is in the spin indexer? I've never seen one but had the idea that they were just notched plates with a dog? What you described maybe sounds a little like mechanical backlash between the encoder and the motor, which makes it tough to do a really tight tuning job.
| Hey Hu, It's a Haas 5-C spinner (CNC). A loose encoder shaft was my first thought. I checked everything - tight and fast. Strange thing is that X and Z axes were happily panting like my dog while the Y was goofy. I tuned it up fine (Y has more mass on a vertical mill) and the PID numbers looked logical. Why did the POSERROR only affect the Y? Perhaps Camsoft can postulate why my symptoms occurred. Nelson
| We're going to start by sending you the current version. You're 2 versions behind. Then once you get this installed we'll have you do some test and make us a History file with the same version we're using. Tech Support CamSoft Corp. support@camsoftcorp.com PH 951-674-8100 Fax 951-674-3110 www.cnccontrols.com
#10
| Thank you Camsoft folks, I got 6.6 today and installed it. On Friday I changed the POSERROR in startup.fil to .0001 and this, thus far, has solved the lurching and oscillating. I had tuned the Y axis by the book as with the other axes. When this problem was seen, it was largely intermittent, between 10 and 50% of the time it occurred. I jotted down the tuning settings as well as the pot settings on the drives and experimented with them trying to solve it a couple months ago. Having the P too high would be a prob, as with the I, the D had less effect on the symptom. On the AMC drives, lowering the loop gain helped fora while then it came back. Very odd that only the Y is affected in that the wiring is the same (shielding, etc). I will try to make the problem happen again for your research benefit. I assume you want a history file in the same manner as before? Thanks, Nelson
#11
| nelZ, Good to hear. If the problem does happen again. Yes, we would like to a history file. Tech Support CamSoft Corp. support@camsoftcorp.com PH 951-674-8100 Fax 951-674-3110 www.cnccontrols.com
#12
| Karl |
| How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? | Calico | PCB milling | 11 | 07-12-2011 06:02 AM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
| Vertical system "jerks" and "bangs"?? | REVCAM_Bob | Servo Motors and Drives | 5 | 06-12-2006 09:09 AM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
