Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
  #13   Ban this user!
Old 04-01-2005, 05:05 PM
murphy625 is on a distinguished road
Originally Posted by intrusion
MurphiesLog StarDate 2005
You can only perform the following statements:
IF
THENIF
But you can also perform loops as you saw in my FILEREAD logic. CamSoft helped me with that.
You can perform quite a bit a stuff with these two using MCODES, GCODES, MACROS and INPUTIO files.
CamSoft has a very helpful front office and I always got a fast response, actually most of the time I get right through to support or a call back within the hour.
Was that a polite way of telling me I ask to many questions?? LOL
I wish there was a case select or an "OR" statement.. hmmm.. Not so bad until you come up with a big complex system with lots of things going on.. That 100 line maximum is killing me because I can not daisy chain two IF statements on the same line..
Any tips?
Thanks Intrusion..
Murphy
  #14   Ban this user!
Old 04-01-2005, 05:37 PM
intrusion is on a distinguished road
100 lines is pretty long and there are neater ways to write logic in CamSoft. You can call macros and unlimted nested macros from what I am told.
You should create some macros and call them from your MCODE. You can have a seperate macro for each series of things that you need to check. When the macro is finished the logic flow will return back to where it branched off from. This way you have no limitations
Example:
IFbla.bla.blaTHEN[CALL MACRO1]
IFbla.bla.blaTHEN[CALL MACRO2]
IFbla.bla.blaTHEN[CALL MACRO3]
After each macro is finished then next IF statement will execute if you need it too.
Unleash your logic
  #15   Ban this user!
Old 04-01-2005, 07:28 PM
oH YA!.. My macro.fil is up to around 40K in size with about 100 of those buggers now.
This camsoft is very compartmentalized and its just taking me a bit to get out of the Visual Basic ways.
Thanks for the tip !!!
Murphy
single line fonts? balsaman General CAM Discussion 12 02-18-2006 11:51 AM
Single Line Fonts A. Shuford General CAM Discussion 1 11-14-2004 08:21 AM
Tool tables Nimrod Mastercam 4 11-24-2003 02:31 PM
Please help me out with the line : G450 CFTCP BanglaTech General CAM Discussion 0 10-25-2003 01:08 AM
Line weight JOE65 Autodesk Software (Autocad, Inventor etc) 4 05-20-2003 11:31 PM
