Results 1 to 8 of 8
Thread: Enable = False while doing other stuff?
    Nov 2004
    I have been wrestling with the "Operational Code" and the order in which things happen with my system.
    To make things short, I want to make the servo enable circuit false while the machine is doing other operations. The servo drive would stay powered on, but it would not be under torque.
    Is there any downside to doing this? What happens if the servo enable = false and the machine gets moved and then the servo enable goes positive? Will this cause a problem with jerking? I'm thinking the camsoft interface is going to want to try keeping position even though it can't..
    This machine has jerked on me before and I never knew why it was doing it. I am quickly learning that making this thing do what I want is easy...Preventing it from doing unexpected things when unusual circumstances occur is turning out to be an educational experience.
    Thanks for your help.. This forum rocks... No wonder it has 10,000 members!
    Murphy
    Dec 2003
    I mentioned this in an earlier post, look up the SH 'Servo Here' code for the Galil, it allows phyisical movement of the axis when not being powered, when power up is restored the axis assumes this position and does not loose counts etc.
    Should be done at e-stop etc, you have to provide a loop that constantly outputs SH.
    Al
    Nov 2004
    Thanks AL,
    I know you posted that in another post.. I could not figure out where it was but I knew you were the one who told me that...
    Thanks!!!
    Nov 2004
    AhAH!!! I just figured out how to use Servo Here (SH) and Motor Off (MO).. (Thanks to AL THE MAN!)
    But I am a little confused.
    The Galil manual says that my amp enable should be TTL active high.. (This means +5V when the motor should be on right??)
    My AmpEnable is connected to an OPTO22 board with an ODC5R (Output DC 5V Reed Relay). Anyhow, the AmpEnable signal is 5volts when my motor should be on and my OPTO board wants the pin shorted to ground to turn on. (which means to me that I need active low)
    I should note that I have had my Ampenable signal connected to a normal output and was turning it on and off manually during testing.. This is the first time I have actually done testing with it connected to the AmpEnableX pin on the ICM2900.
    Anyhow, to make a long story short, it would seem that I need to replace a 7407 IC chip inside my ICM2900 with a 7406 chip..( Page 14 chpt 2 of the galil manual).
    Are all 7406 IC chips created equal ?? Can I get this from Radio Shack or Ebay?? Or is this something I need to call Galil about??
    Thanks!!!
    Murphy
    Dec 2003
    The 7407 ic will invert the Enable signals, If you have local Electronics supply places like Radio shack, Virually any flavour of 7407 will work. They are only a few cents, if you have to bring one in the shipping will be 10x the IC.
    If you only have one to invert, you could use a single transistor to act as an inverter, I keep a stock of 2n7000 on hand for this purpose.
    Al
    Mar 2003
    Search "7406" on ebay and you'll find a store that sells 10 chips for a dollar plus 5.95 shipping. Three days in the mail. Radio Shack doesn't have em.
    I am also figuring out a retro. The terminology is difficult for me to understand. Enable high, true high, floating high, sink, source,... it sure isn't like the knob and tube wiring in the milking barn.
    The opto22 parts should integrate without any trouble. Which board you are using when your write "board wants pin shorted to ground"? I use grayhill boards that allow either negative true or positive true logic. They only hold four modules, but I don't need a header cable to connect. I can wire them a few different ways depending on the application.
    There is a schematic for a opto22 board here. Is this what you are using?
    http://www.opto22.com/asset/document...data_sheet.pdf
    If so, maybe someone else can take a look and decipher.
    Dec 2003
    The ODC5R is negative logic only, AFAIK.
    Some of the Opto boards that have termination screws for both logic and power can be configured for both, but you have to use a relay that is capable of both sink & source logic.
    Al
    Nov 2004
    Quote Originally Posted by keithorr
    Yes.. that pdf file is what I am using.. ODC5R.. I have that pluged into an opto22 PB16T board that I hook up all outputs from my ICM2900 to.
    Here is the link to the board.
    (Opto or no opto option, I like the extra layer of isolation the optos give me.. (even though the ODC5R is a dry contact its all I had to work with)
    I dont get the terminology either.. But I do understand the phrase "Sink it to Ground"
    I called around to my local electronics places. No one has this darn chip...
    Murphy
    1. great stuff to work with
      By trubleshtr in forum 80/20, TSLOTS and other Aluminum Framing Systems
      Last Post: 02-06-2009, 10:41 PM
    2. Testing for drive enable?
      By murphy625 in forum CamSoft Products
      Last Post: 04-06-2005, 05:04 PM
    3. Connecting Amp Enable
      By keithorr in forum CamSoft Products
      Last Post: 03-21-2005, 06:31 PM
    4. welding thick stuff to thin stuff - need advice
      By cross6 in forum Welding, Brazing, Soldering, Sealing
      Last Post: 01-13-2005, 02:39 AM
    5. Active High/Active Low
      By Sanghera in forum General Electronics Discussion
      Last Post: 11-06-2004, 09:47 PM
