| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
Hello, all. I am new to CamSoft, coming from an old Tree vertical mill, which now has a Camsoft control on it. I am having good results, but am still have much of my learning curve ahead of me. Here is my problem: When I call out a rapid move, my machine travels as if it was in feed mode. Really slooow. Not knowing enough about this program, I am not sure if it's my toolpath writing or my machine parameters. also, when calling oiut an M6, the spindle takes forever to retract. Here is a short program I wrote to drill some holes. No where do I see a rapid command. Do I need to specify rapid when creating toolpath, then feed? % N10 T18 M6 N20 G90 S2000 M3 N30 G83 X.469 Y-.5 Z-.6 R.1 F8. N40 X3.469 N50 X4.406 N60 X7.406 N70 X8.343 N80 X11.343 N90 X12.28 N100 X15.28 N110 Y-2.5 N120 X12.28 N130 X11.343 N140 X8.343 N150 X7.406 N160 X4.406 N170 X3.469 N180 X.469 N190 M30 % Thanks, Tom
__________________ http://tcurran.com/ Last edited by Tom Curran; 11-23-2009 at 05:39 PM. |
| Well, your program has no G0 - rapid moves. Depending on how M6 and G83 was written, they may contain rapid moves. Test your machine with a G0 move. If you want to go faster, change the maximum speed in CNCsetup. You need to watch for performance issues with your steppers or servos when making changes here. There is also a RAPIDSPEED command so you can change the maximum speed in any of your macros. I'd do a search on your .cbk for this command to see if this is used anywhere. Karl |
| increasesing rapid on SL-30 | MBG | Haas Lathes | 1 | 10-06-2008 05:44 AM |
| MDI rapid vs jog problem | Chris64 | Mach Software (ArtSoft software) | 4 | 03-08-2008 09:34 AM |
| Fanuc Oi rapid traverse problem | longcut | Fanuc | 2 | 11-22-2006 03:03 PM |
| 2.5D pocketing rapid problem | mayhugh1 | SprutCAM | 3 | 11-02-2006 01:58 AM |
| lathe wont rapid above 25% encoder problem????? | imwllc | General Metal Working Machines | 2 | 08-01-2005 07:54 AM |
