| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
| I use CamSoft software to build 2 axis CNC lathe machine. I have home problem. Although I drive home position, motors have no any movement. But , after press spindle drive CW buttom, when I press the home buttom, home routine is working. I want to get CNC setting file or .CBK file for 2 axis CNC Lathe Machine. Very welcome teach me and any suggestion With my respect, Mr. Kyaw |
| I understand you to have two questions: You press a button to command machine to move home and you get no response. But it works later. For this, I suggest you go to the diagnostic page and press the "Why am I not moving" button in the lower right corner of the window. I am assuming you have the machine jogging, limit switches working, spindle turns on/off Your second question is for a default .cbk for your machine. The software comes with several to choose from. I suggest you load all the lathe ones in demo mode and get a feel for the features each one has to offer. Then choose the one with the closest fit to your needs. And you can easily import features you like in the other .cbk files Karl Last edited by Karl_T; 11-19-2009 at 03:53 PM. Reason: i can't spell |
| thank you for your help , and any suggestion and guideline My PC based CNC is for 2 axis Lathe only Although press F12 (home fine buttom), no any movement. After that, open the diagnosis and I press "the why no motion button", it shows like that In IPR mode and spindle is not runing Feedrate is too slow Motor 1: Has not reached last command position yet, waring Motot 2: Has not reached last command position yet, waring Test Completed Report written to C:\AS3000\CNC\logfile.fil my home routine like that :HOMEXY STOP MACHZERO 0;0;0 \1=0 \2=0 IF#1=0THENIF#2=0THENGOTO :HOMED IF#1=1THEN\1=-100 IF#2=1THEN\2=-100 f=50 SUSPEND BYPASS MACHGO \1;\2 :LOOP IF\1<0THENIF#1=0THENSTOP:GOTO :HOMEXY IF\2<0THENIF#2=0THENSTOP:GOTO :HOMEXY GOTO :LOOP :HOMED 'for more accuracy backoff home switch slowly until states change off STOP MACHZERO 0;0 f=10 ' FIND HOME SWITCH OFF ON Z AXIS SUSPEND BYPASS MACHGO 10;0;0 WAITUNTIL #1=1:STOP MACHZERO 0;0 f=10 ' FIND HOME SWITCH OFF ON X AXIS SUSPEND BYPASS MACHGO 0;10;0 WAITUNTIL #2=1:STOP MACHZERO 0;0 LIGHT 5;ON MESSAGE MACHINE IS HOME ----M120 |
| Newbie- Part Home vs. Machine Home | Mihelich | G-Code Programing | 6 | 06-07-2009 01:56 PM |
| Need Help!- machine home problem | traxxtito | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 04-27-2009 03:15 PM |
| home problem with mach 3 | Bill Wann | Machines running Mach Software | 1 | 07-28-2006 10:04 PM |
| Mach3 limit switch problem on Ref Home | originator | Mach Software (ArtSoft software) | 1 | 03-13-2006 08:02 AM |
