| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
CAM SOFT PRO, Galil 1840 Rev C, 2 axis gantry with 3rd axis slaved to 1st. Last week it was as smoth as silk. Today the goofy ghost came, and the machine pauses for about 1/2 second at the end of every G1 or G2 line of code, using an oxy fuel torch it leaves witness marks that have to be welded up and sanded out, because of the jerky start stop motion. Called CAM SOFT and they suggested changing smoothing to -50 or servo tuning. any # more than 5 above or below exhisting PID will cause the machine to chattter and jerk or go slow and then jump to position, so the tuning is about as close to middle of road as possible. smoothing at any number had no effect. tollerance on general settings page from .001 to.01 had no effect on the opperation. the only thing differrent is a new touch screen control panel and an Opto 22 board with 4 new M codes to operate solenoids. This will make you want to plow in a circle. Thanks The Farmer |
| You need basic invetigation techniques here. On something that has worked a long time, then broke, I asked what changed recently? When the operator (may be you) says it can't be that, I think "Oh yes, it can". You've got to have a bunch of new code in your .cbk for that touch screen. Before even starting it sure sounds to me like DECELSTOP is in effect. I'd search a log file for this command. If you don't find it with one or two quick guesses, start by dividing the big problem into two smaller ones. For example load a default .cbk that you used when you first got the machine and only change your PID settings. Does the machine perform correctly regarding this issue? If yes, you know its in the .cbk somehow. If no, look to hardware or Galil programming. Keep narrowing down till you find it. Good luck Karl |
| Karl |
| Fadal 4020 stops at line 13 or 16 in program | ThatguyDave | Fadal | 10 | 09-09-2009 02:57 PM |
| Need Help!- Single line G76 code! | Jack6931 | General Metalwork Discussion | 0 | 06-16-2009 09:43 AM |
| I put Carriage stops / E-stops on the x&y Shoptask 1739 Gunmaster....I was bored lol | spunky1974 | Shopmaster/Shoptask | 0 | 06-30-2007 04:13 PM |
| G-Code Line Numbers? | Imagineering | G-Code Programing | 3 | 08-17-2005 07:26 AM |
| Perhaps a bug in simple one line code?? | thuffner3 | TurboCNC | 3 | 02-02-2004 08:21 PM |
