Results 1 to 1 of 1
Thread: decimal point Gcodes G90.1 G91.1
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    Gcodes with a decimal point are common on modern CNC controls. I've seen no mention of this in the Camsoft literature. It turns out writing Gcodes with a decimal point is easy to do in Camsoft.
    The attached file has modified G90 that also does G90.1 - absolute ijk circular arc, G90.2 - radius mode circular arcs. Also is a G91 that is modified to include G91.1 incremental ijk arcs.
    These Gcodes got a bit more tricky when allowing for more than one G90 or G91 code on a line, i.e. G90 G90.1 Extra bonus question: My Gcodes actually run twice if you have two gcodes on the same line. No harm done, but not perfectly elegant. Anybody have a fix to make this code just run once?
    Enjoy
    Karl
    Attached Files Attached Files
  1. Forcing a decimal point from a pci
    By inflateable in forum EdgeCam
    Last Post: 10-28-2008, 09:58 AM
  2. Illegal use of decimal point
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 07-07-2008, 07:06 PM
  3. decimal point
    By stevieboy in forum Mastercam
    Last Post: 01-10-2007, 06:42 AM
  4. Decimal point placement
    By Zeekh in forum Haas Mills
    Last Post: 11-04-2006, 08:18 PM
  5. help with gcodes
    By turmite in forum General CAM Discussion
    Last Post: 03-30-2004, 04:36 PM
