Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 03-14-2005, 09:20 PM
keithorr is on a distinguished road
Connecting Amp Enable
I am connecting servo amplifiers to an ICM2900 OPTO module. I am configuring for low enable (replacing the ic chip with a 7406 model), pulling the resistor pack to make the it an open collector (ampenx,y,x....) .
The enable pin on the servo amplifier sources 15v. (Sanyo 27BA100FFT and 27BA030FXT amplifiers)
The goal is to sink the signal to ground.
I read and have been informed that the current limit of the ic chip is 40mA.
When I manually short the amplifier enable pin to ground through a mulit-meter, the readings are 7.4-7.6mA at about 12.75vdc.
I have seven amplifiers.
How do I protect the ic chip? I assume I will place resistors in line, but don't know how to determine the proper size or if that is the right strategy.
I think this smiliey describes it best
Old 03-15-2005, 12:25 PM
agentsmith's Avatar
agentsmith is on a distinguished road
To get started on the right foot it may be best to contact Galil directly on this issue. This is a special case. Most people don't have to do this. I myself never had to use resister pack or build build special circuits. But it is possible to do this. If you contact Galil they can help you and make sure that your circuit will not damage the board. I've been using Camsoft for years and this sounds like a deep subject that is best explained by someone that really knows what their doing.
Good Luck
Old 03-15-2005, 01:05 PM
Mr. Smith
I thought I would try here just to see. Actually the solution occured to me on the way home last night. I am connecting only 4 amplifiers per ICM module, not 7 (4 on one module, 3 on the other). I was fixating on a 25¢ part and forgetting the context. Four amp enable lines drawing 7.6mA is within the limits of the chip.
In the words of Emily Litella, "Nevermind".
Old 03-20-2005, 03:01 PM
murphy625 is on a distinguished road
I had a problem like this also.
My servo uses a 24volt enable signal and the icm only accepts 5 votls.
I used the 5 volts to drive a stand alone Opto22 relay. (cheap $$)
The enable from the ICM turns the opto on and off and the opto passes the 24 volts from the enable circuit.
Works great. No problems.
Murphy
Old 03-21-2005, 12:41 PM
intrusion is on a distinguished road
Murphy,
That sounds good, however there is a way to get 24V on the ICM for the enable circuit. I read in the Galil manual and CamSoft's that you can remove a resister pack (RP1) and apply your own resister in series with the external power supply up to 24V.
intrusion
Old 03-21-2005, 06:31 PM
Originally Posted by intrusion
Murphy,
intrusion
I just found it much easier to use an opto relay.. The new G4's have a manual switch on them that lets you turn them on and off manually without the computer. (comes in handy sometimes).
I would also think that it would provide another level of protection to the computer due to the fact the relays are optically isolated.
Just a suggestion.. I'm just a newbie.
Murphy
West Amp Servomotor help johnd Servo Motors and Drives 9 12-11-2008 04:20 PM
AMP Connector for Bridgeport Boss 8? Bill Gillen Bridgeport and Hardinge Mills 2 05-07-2005 12:19 AM
Enable = False while doing other stuff? murphy625 CamSoft Products 7 03-30-2005 01:48 PM
Active High/Active Low Sanghera General Electronics Discussion 21 11-06-2004 09:47 PM
200 Oz-In 6.5 Amp Bipolar Parallel motomitch1 General Electronics Discussion 9 05-06-2003 03:07 PM
