I answered the question TRUE to save postion and then display on start up but it always comes up with some goofy numbers in X and Y when I start up my torch. It is not set up to go home on start up like a mill or lathe would do and I dont type in G54 to run a program, just set X and Y zero and start to cut. I want to mount a bridgeport mill head beside the torch carrage to pre drill bolt holes in large gussetts and shear tabs and drill the holes in G55 and torch in G54 the mill head will always be same distance from torch center, like 18" so it would be simple to set up cordinates. where in the CNC pro software are the work cordinates?, or how to make a button to toggle between them?
The Farmer
LinkBack URL
About LinkBacks
