Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 09-08-2009, 10:25 AM
Kyawsoelwin(MC) is on a distinguished road
Can I use Suqiang SN2000 servo drive with Camsoft Software?
Hello everybody,
I have Suqiang SN2000 Digital AC Servo drive. I want to use these drive with CamSoft PC Based CNC Software. I have no experience about with servo drive.
with my regard,
Mr. Kyaw
Old 09-08-2009, 10:33 AM
Al_The_Man's Avatar
Check the manual to see if the drive accepts ±10vdc analogue drive signal.
Also check if the drives pass on the encoder signal.
Old 09-08-2009, 10:47 PM
suqiang SN2000 Servo problem with Camsoft
Dear Al_The_Man,
I have checked the SN2000 servo drive. I see two types of standard connection, one is position control mode and another is speed control mode. In position mode, there are podition dictate PLUS & SIGN input signal and CCW drive forbid & CW drive forbid. In speed mode, there are Analoge dectate input & Analoge input ground. Which type should I select for CNC control?
Thanks you for your helping
Old 09-09-2009, 07:56 AM
Al_The_Man's Avatar
The Galil card uses ±10vdc analogue drive signal, so if the drive takes this, as it appears it does, use this input.
You could maybe set the card for stepper operation and use the step dir signals but the loop would be closed back to the drive only, it would not be my preference.
Old 09-09-2009, 10:05 PM
PULSE and SIGN input signal
Although my existing servo drive has PULSE and SIGN input signal, it is servo drive and servo motor. It hard to interface for me. Can I use this servo drive as a stepper drive? Could display show realtime movement without encoder feedback to Galil motion control card?
Thanks you for your reply
Old 09-10-2009, 06:31 AM
Karl_T's Avatar
Karl_T is on a distinguished road
As Al said, a stepper type setup would be a very poor second choice. You will loose Galil feedback.
Old 09-10-2009, 09:42 AM
Red face Should we select position mode or speed mode for numerical control?
Dear sir,
Does Analog signal (+/-10 VDC) represent as speed command for servo drive? My existing Suqiang SN2000 servo drive has these two mode. Although it's servo drive has analog input and analog ground, I have never seen Analog signal (+/-10 VDC) in that servo drive manual. For position mode, it includes PULS & SIGN input signal and it has analog input & ground for speed mode. What type should we select position mode or speed mode for numerial control?
Thank you for your reply
Old 09-10-2009, 01:20 PM
Al_The_Man's Avatar
Without looking the manual over it is a bit difficult to give a definitive answer, It is very unusual for a servo drive to have uni-potential analogue, i.e. 0-10v, this is often seen on spindle drives where the direction is reverse by a separate input signal.
I would say out of the two it would be position mode rather than velocity.
Newbie- CNC Lathe - Servo direct drive or pulley drive? s76tools General Metal Working Machines 1 09-06-2009 11:17 AM
Can I use Suqiang SN2000 Serial Servo motor drive with Mach3 hightechkey Mach Lathe 3 09-04-2009 05:33 PM
Galil Motion Controller, with NEMA 23 Servo Motors, Servo Drive, Encoders, Etc. qualitymachine EBAY ADS 0 06-01-2009 02:26 PM
Servo tunning in CAMSOFT Pro Colin CamSoft Products 13 02-05-2007 08:44 AM
Reloading Camsoft Software palmerjv CamSoft Products 8 08-29-2005 10:05 AM
