Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 08-18-2009, 05:12 PM
hoyospetrola is on a distinguished road
G0 deceleration problem.
Hi, i have a camsoft cnc lite software with a servocard cs16600 and i have a problem, when it makes a G0 when it decelerates it does but like in two times, it decelerates very fast but not stopping, then it continues moving till it´s final destination very very slow, that makes the G0 movements very slow. I tried changing different acc and dec values and different max speed values but the problem persist. Anybody knows what happens????????
Old 08-19-2009, 06:49 AM
Karl_T's Avatar
Karl_T is on a distinguished road
Is this Camsoft's proprietary card?
If not, we could do some do some direct Galil commands. I won't mention them unless this is the card you have.
Look into TOLERANCE BLEND (and one other). Sorry I'm on the road, no manual in my pocket. I'm guessing you have something spec too tight here. Its taking the control too long to satisfy your requirments.
Karl
Old 08-19-2009, 08:56 AM
a graph of the problem
Hi Karl, thanks a million for your help. Buth the problem is that the slow motion movement happens much earlier that the end of the G0. attached a graph so you will be able to see how the G0 mov happens. Usually is like 25cm earlier than the end of the G0 machine slows and the last 25cm of that positioning are very slowly, have a look on that graph.
Old 08-19-2009, 08:59 AM
Unhappy No galil card
Other thing that could affect is that the card they sold me so called cs16600 is not a galil card and as i can see looks like if all that software is designed for galil cards, i have not option to send native comands to the control card for example.
Old 08-20-2009, 07:18 AM
Karl_T's Avatar
Haven't got a clue on this one. I've not worked with this card either. Hope you're on Camsoft maintenance
I've often "started over" There is a wizard that will build you a new .cbk in just a few minutes to test motion. At least you could confirm if its a logic or card issue.
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
Need Help!- Finding Cutting time from a program considering machine acceleration and deceleration yaji63 G-Code Programing 0 07-31-2008 04:35 AM
No Deceleration code star1280 G-Code Programing 0 05-30-2007 11:36 AM
V2XT Quilt limit deceleration settings Spin Bridgeport and Hardinge Mills 0 02-16-2006 09:10 PM
acceleration/deceleration of masses Pat2000 Mechanical Calculations/Engineering Design 5 11-06-2005 05:51 PM
