| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
I get an error every time I try to run a G02 or G03 code. With the parameters set to absolute when I run. G90 T1M6 G05 G17 G01 Z-.1 F75. G02 X1. Y1. I1. G01 Y2. G02 X2. Y3. I2. J2 G01 Y4. G01 X1. G03 X0. Y3. I1 J3 G01 Y0. M30 I get the error "Start Radius of Arc Differs from end Radius" With the parameter set to incremental and I run the code: G91 T1M6 G06 G17 G01 Z-.1 F75. G02 X1. Y1. I1. G01 Y1. G02 X1. Y1. I1. G01 Y1. G01 X-1. G03 X-1. Y-1. J-1 G01 Y-3. M30 % M 30 I get the same error. If I set the parameters to Radius and run the code: G90 T1M6 G17 G01 Z-.1 F75. G02 X1. Y1. R1. G01 Y2. G02 X2. Y3. R1. G01 Y4. G01 X1. G03 X0. Y3. R1. G01 Y0. M30 I get the error "Radius is zero, Illegal Command" When I run these through my tool path plotter program they run fine. I am lost here, and suggestions would be appreciated. It is hard to have a milling program without a G02 or G03 anywhere for the type work we do. Please let me know if any more information would be helpful. Dan |
| Dan, All 3 versions of the G code run through without error producing the same shape as long as you have the FANUCARC check box set correctly before loading each G code file version on the TOOL PARAMETER screen or else on the SETUP screen under General Settings. Tech Support CamSoft Corp. support@camsoftcorp.com PH 951-674-8100 Fax 951-674-3110 www.cnccontrols.com
| We have ours set to Galil mode as well. All 3 run through fine, no errors in Galil mode. It's not the Galil mode setting that matters. It's the FANUCARC setting for Absolute, Incremental or R code for radius choice that makes the difference when using G2's or G3's. Also if you have CNC Pro there's the R value in the G code file. It you use CNC Lite or Plus or either CNC Pro in Absolute or Incremental mode the R value won't matter. Tech Support CamSoft Corp. support@camsoftcorp.com PH 951-674-8100 Fax 951-674-3110 www.cnccontrols.com
| Perhaps I should go over the steps I take again: Step 1 Boot PC Step 2 Start CamsoftLite Step 3 Click on the little tool box and set FANUC ARC Centers to absolute (0), click the little check mark to close screen. Step 4 Load absolute program Step 5 open MDI screen to see current program Step 6 Verify I have opened the absolute program Step 7 close MDI window Step 8 click Cycle Start Step 9 Get Error message I then exit the program and start new, this time Step 3 is set arc centers to incremental Step 5 load incremental program Same routine for Radius I have spent hours trying everything I can think of and am still getting errors. Thanks again Dan |
| Dan, That's good. We used the same steps and it works okay. Are you sure you have the Machine type set to MILL3D? And not Lathe or some other machine type? If not under General Setting enter MILL3D in the MACHINE TYPE box. If so using SETUP , RESTORE the CNCLITE.CBK file and run your "Incremental G code" program through. If it works then you'll need to contact us to give us your latest CBK file so we can investigate the settings in your CBK. If CNCLITE.CBK doesn't work then we need to talk to you on the phone "live" to figure this out, get your company name , serial number and version ect...
Try this, set FANUCARC=0 then run this G01 X1 Y0 F10 G02 X1 Y0 I0 J0 Your should get a full circle. Karl |
#10
Thanks again Dan |
#11
| Modify your G02 and G03: QUESTION 131 How do I use the R Code for turning a radius instead of I, J & K? The first thing to do is to use the CNCSETUP.EXE program to set the FANUCARC parameter to equal 2. The second thing is change the format of the CW and CCW commands in your GCODE.FIL file for G02 and G03 to the following format: EXAMPLE: CW x;y;z;r CCW x;y;z;r (I don't have time tonight, but I could write you a G02 and G03 that does both i,j and r. Tell me what custom G code numbers your'd like to call to do the switch. kinda like G90 is abs and G91 is inc.) Run this gcode G01 X1 Y0 F10 G03 X0 Y1 R1 You'll get 90 degrees CCW starting at 1,0 and ending at 0,1 |
#12
| Here's some untested code to switch among the three FANUCARC modes. I'll use G95 to set absolute arc centers, G96 for incrmental arc centers, G97 for radius arc designation. In startup.fil, define your default. Add these lines FANUCARC=0 'absolute arc centers \75=0 'arc type, 0 is abs. modify your gcode file FANUCARC=0 \75=0 MESSAGE Absolute arcs --G95 FANUCARC=1 \75=1 MESSAGE Incremental arcs --G96 FANUCARC=2 \75=2 MESSAGE radius arcs --G97 here's my existing G02, yours may be different DISPLAY4 {f} DISPLAY5 {s} TIME CYCLE;\4 DISPLAY7 \4 RUNTIME \4 DISPLAY8 \4 CW x;y;z;i;j;k -----G2 Let's make it like this: DISPLAY4 {f} DISPLAY5 {s} TIME CYCLE;\4 DISPLAY7 \4 RUNTIME \4 DISPLAY8 \4 IF \75<2 THEN CW x;y;z;i;j;k IF \75=2 THEN CW x;y;z;r -----G2 Do the same for G3 NOTE: i write for Pro, your version has a ! in front of every line. And less commands, I don't know which ones you're missing. Now just write the arc type in your Gcode: G1 X1 Y0 F10 G95 G2 X1 Y0 I0 J0 'full circle G96 G2 X1 Y0 I-1 J0 'ANOTHER FULL CIRCLE IN INCREMENTAL G97 G2 X0 Y1 R1 '90 DEGREE ARC karl PS I probably left at least one error for you to find. |
| ncnet lite | krustykrab | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 02-10-2010 01:15 AM |
| looking for CAD 'lite' software | mosesralph | CNCzone Club House | 5 | 03-23-2009 04:36 PM |
| Help me decipher Camsoft error message please | bobbillbee | CamSoft Products | 2 | 03-16-2009 07:55 PM |
| Camsoft error | KARD | CamSoft Products | 3 | 08-16-2007 09:18 PM |
| Galil 2xxx and Camsoft CNC Pro/Plus/Lite??? | corbyvhall | CamSoft Products | 1 | 12-07-2005 10:56 AM |
