Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 03-10-2009, 11:46 AM
Karl_T's Avatar
Karl_T is on a distinguished road
LASER scanning
I bought a LASER displacement sensor off eBay with the idea of scanning parts. This sensor outputs the very common 4-20 milliamp. A galil board needs 0-10 volts. I started with a very simple resistor for the conversion but found a ripple in the voltage reduced accuracy. So a EE friend designed the attached 4-20 milliamp to 0-10 volt converter. Also attached is a graph of this Omron sensor performance.
Next I wrote code for my mill's .cbk file. See the attached text file. This code uses G101 to record LASER displacement sensor values to a file. The format of this Gcode is G101 X_ Y_ I_ F_ X,Y,F work just like G1 in any Gcode. I is the increment between laser readings. To scan a part, write a Gcode file to run the laser over as many passes as needed. Parametric programming (looping and incrementing X or Y) can keep this program fairly small.
So far, I've scanned as fast as 4ipm with readings every 0.002" with good results.
Enjoy
Karl
File Type: txt 4-20-TO-.BOM.txt‎ (882 Bytes, 69 views)
Old 03-10-2009, 12:00 PM
Adamj12b is on a distinguished road
Very Interesting. Do you have a link to the sensor that you used? Was it expensive?
As for the 0-10V output, what is the purpose of this? Dose it have something to do with height.
Also, What kind of machine are you running this on.
-Adam
www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
Old 03-10-2009, 01:10 PM
Karl_T's Avatar
-Adam
http://www.omron247.com/marcom/pdfcatal.nsf/PDFLookupByUniqueID/46021884A762C2E086256A31006B2E69/$File/D02Z4MWR0401.pdf?OpenElement
Promise not to call the sheriff? I stole it - $80.
Laser displacment sensors like this one put out an analog value proportional to the distance or Z height in this setup
Camsoft control on an Excello knee mill
Old 03-12-2009, 10:26 PM
XYZADave is on a distinguished road
Results?
Hello,
Any chance you could post some results, (pics)???
Thanks Dave
Old 03-20-2009, 04:30 PM
Karl_T's Avatar
Laser scan arcs
Here's a macro to laser displacement scan arcs.
My concept: Scanning a grid of readings to a file just gives a point cloud that is complex, at best, to turn into a CNC program to replicate a scanned surface.
I have found that with a little study a CNC program can written for the X and Y coordinates on how a replicated part surface should be machined.
1) I write this program and test.
2) Then change all G01 to G101, all G02 to G102, all G03 to G103. Run the Laser displacement sensor programs to get the Z depths.
3) Rewrite the program in 1) with Z depths. Machine part.
This goes really fast, no complex design time. I've done a couple parts, only downside is careful inspection for error readings is needed. Edges are giving the most trouble.
Karl
Old 04-18-2009, 10:26 PM
Farmers Machine is on a distinguished road
So you are using your mill as a CMM to reverse engineer your part?
Does it record the measurments into your CNC control or into a seperate CAM package? are you using the Cam Soft 3000 or something different. I saw the laser on there web site and was thinking about building a measurment machine. but mounting the laser to the mill takes care of a lot of issues.
Thank You
Farmers Machine
Old 04-19-2009, 06:24 AM
Karl_T's Avatar
Thank You
Farmers Machine
Yes, poor man's CMM. Exceptional accuracy if you pay attention to detail.
The data is recorded to a text file as a series of X Y Z coordinates.
You quickly end up with a HUGE number of points, or point cloud. A package called Rhino can handle the data and turn it into a model that is in turn imported to a CAM package. This is NOT my area.
I found a shortcut for the parts I needed to copy. Carefully plan your X and Y moves to machine the part; write this Gcode file. (Note that my G101 is linear laser read, G102 is CW laser read, G103 is CCW laser read). Spend some time thinking exactly where you need Z readings. Now modify the Gcode (add 100, put in read increments) to read your Z values off the part and run laser program. Input your Z values into the original program(I automated this step) and you are ready to machine.
Karl
3D Laser Scanning Services Offered GJMATHEWS Product Announcements & Manufacturer News 8 06-14-2010 04:04 PM
What is best for scanning? Led or tube laser? jaru-eri Digitizing and Laser Digitizing 0 06-08-2008 04:01 PM
scanning on the tormach RB1 Tormach PCNC 4 01-10-2008 12:18 PM
Need Laser Scanning Advice Rico55 Digitizing and Laser Digitizing 5 09-20-2007 08:33 AM
Is this the way 3d scanning will go ? greybeard Digitizing and Laser Digitizing 5 02-15-2007 11:52 AM
