| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
A lot of my machining involves drill and tapping. I've had a need to able to put a tap in a collet and rigid tap for some time. This should work in theory as Galil supports electronic gearing. But there is no mention of this ability for a mill without a servo spindle in the Camsoft manuals. I have a 2J type head on a CNC knee mill. The spindle is run by a VFD. Getting rigid tapping to work turned out to be an epic struggle. At one point the great<Camsoft> technical help implied that it might not be possible to do this on a machine without a servo drive spindle. Today, I'm here to say that doing the difficult with Camsoft is routine. Impossible just takes a little longer. After I got G84 working, I spent another day and improved all the other canned cycles as well. I made an effort to comment the heck out of the code so that most any programmer can follow the logic. I'm sure the macros will take some minor mods to run on another machine. Attached is the code for all canned cycles. Enjoy Karl |
| I came back to rigid tapping a few weeks ago and had trouble. Find Index (galil FI) quit working reliably, don't know why. I also had troulbe with resetting registers again. Do a search and replace as outlined below. The macro worked with these changes for the last couple weeks. IF \864=0 THEN COMMAND DP,,,,0:COMMAND GA ,,E :COMMAND GR ,,\860 'if first time through;FindIndex mark,set spindle to slave Z,electronic gear ratio 'NOTE changed to DP,,,,0 on 04 05 09 program bugging on FI ...clipped main program.... COMMAND GR ,,0 'turn off electronic gearing 'MACHDISP 'MACHHOME3 \868 'current home readout 'MACHZERO ;;\868 'rezero to current home readout 'ABSDISP 'NOTE: Above 4 lines needed because registers get confused with electronic gearing SLEEP 1.0 READOUT3 \869 'current Z position HOMEZ \869 'NOTE first four lines above bugging 04 10 09, second trial |
| Have almost got the kit ordered, but it just dawned on me that I have not heard much of the rigid tapping option. I read these posts recently, and ass u me that all is well, but you never said what it was exactly that you used instead of the servo motor I don't think? I ass u me'd that you found a way to mount an encoder off the actual spindle somehow? A servo motor shouldn't really be what is needed exactly is it? I have a resolver that is set originally for spindle orient that I am planning on upgrading, and I would like to think that CamSoft can work with that eh? I would think it to be perfect, but the words "Rigid Tap" only pull up 5 threads total, and only this one is titled as related. 2 of the others are locked! (Those may be worth investigating?)(Turns out they are 5 to 6 yrs old and I am sure that some things have changed since then eh?) I am more interested in hearing from someone that "is tapping" or maybe more importantly "Aint Tapping" then someone saying that it can be done. But I would appreciate any comments. ![]() --------------- Think Snow Eh! Ox |
| No 1, you need an encoder driven off the final spindle shaft. If you take a look at commercial systems like Mitsubishi and Fanuc etc, they use tight control of the spindle, although the drive is basically a AC Vector rated motor & VFD, the system usually has a pulse generator or encoder of some kind on the motor back to the VFD for accurate control of the motor, as well as the encoder on the final shaft to gear the Z axis to. I have found so far that the Galil gearing feature works well, you would need to confirm with Camsoft as to how well it works with their system. You may have a problem integrating a resolver with Galil however. Al..
| I've tapped a few thousand holes. Werks grate! Karl |
| Did a gander at your macro and I see that you were using your back geared setup in the equassion and that _ that was the issue at hand. My setup has the encoder 1/1 with the spindle so it should be elementary.... ... but as is noted on G84 - it denotes "NON-rigid tapping". Not "Rigid". Will the canned G84 doo rigid as is? And if so - why doo they call it "NON"? Also - I have a 3 speed geared head and I fully expect it should tap in any gear as the encoder is on the spindle shaft it'self. (Or driven off of enyways...) ------------ Think Snow Eh! Ox |
You're WAY ahead being able to go right on the spindle. makes life much easier. Yes, this custom macro is for rigid tapping only. I'm not sure where you're reading about NON-rigid tapping but it does not apply. I'm glad to see somebody using this work. Let me know when the chips are curling Karl |
#10
| OK i was wondering how can i program a jump height into the drilling cycles i need a p plane programmed into the cycles because of clamps and different sized parts i cant seem to get this to work for me and its a serious problem thanks ahead of time for any help. mike |
#11
| The G84 canned cycle like most of the other canned cycles has a R word for Rapid Clearance plane where the value after the R is the Z height to jump to clear clamps or fixtures. Tech Support CamSoft Corp. support@camsoftcorp.com PH 951-674-8100 Fax 951-674-3110 PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
#12
| ya but if you put in say R5.0 it will start feeding from that point im talking about whats called a P plane as in any other controllers it will be listed as say G00 Z5.000 G81 Z-.300 R.1 F1.5 P1 X0.0 Y0.0 P1 is a jump height of 5 inches between holes rapid plane remains at .1 as of now the only way i see to do it is to create a new drill cycle for each hole |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Tapping head or rigid tapping | Gregory_C | Syil Products | 2 | 10-18-2008 12:49 AM |
| Rigid Tapping | JIMMY | Mastercam | 9 | 09-19-2007 12:28 PM |
| Help with rigid tapping | bob1371 | Fanuc | 6 | 07-20-2007 11:15 AM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
