Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 12-09-2008, 10:41 AM
nelZ's Avatar
nelZ is on a distinguished road
Camsoft and Bobcad ???
Howdy!
I have version 19 Bobcad and a machine with Camsoft control. I got the post processor from Bobcad for Camsoft, it's installed.
It's iffy in that - I'm trying to do a G83 peck cycle and it does not always bring up the dialog box asking for the pecking parameters. After I select the G83 from the cycle dropdown it just generates the code without the other (necessary) parameters...
Anybody have a similar problem, OR is there another post processor which might work better for Camsoft?
Thank You
nelZ
i build the braces that keep american teeth straight......tick tick tick
Old 12-09-2008, 01:21 PM
Karl_T's Avatar
Karl_T is on a distinguished road
By pure coincidence, I spent the morning writing a fanuc compatible G83 code for Camsoft pro. I'm doing all of G81 to G86 this week. My goal is to have them 100% compatible with the mastercam 6M fanuc post.
it depends on where you're an expert, you'll have either edit your post or camsoft gcodes to make them 100% compatible. I find it easier, and better in the long run, to edit camsoft
Karl
Old 01-21-2011, 09:39 AM
machinationus is on a distinguished road
its BobCad
Originally Posted by nelZ View Post
Howdy!
Thank You
nelZ
You may have to modify the BobCad script file :
From BobCad Ver. 21 not sure if it works in Ver.19
'G83 ISO Peck drilling cycle
OptionsConfiguration Rel = FALSE
OptionsUnits Output, Unit = UN
NCEdit Output,Line = i
dim R as string
dim F as Single
dim Q as string
dim DEPTH as Single
dim MODE as integer
Dim FLAT as Single
Dim ANG as Single
Dim DIA as Single
dim CCS as Single
dim FPR as Single
dim RPM as integer
MODE = 98
R = .1
F = 0
DEPTH = (-1.*UN)
RPM = 0
Q = .05
DIA = .500
ANG = 118
FLAT = .010
FD = -0.00
Ask Header="G83 PECK Drill Full Depth Speed Calculator (1 of 3)", Output, Cancel=canc, "Drill Diameter;0"=DIA, "Included Angle (up to 179.99);0"=ANG, "Tip Diameter;0"=FLAT
if canc Then
Exit
Endif
CCS = 100 ' cutting speed
FPR = .003 ' Feed per rev.
Ask Header="G83 PECK Drill Full Depth (2 of 3)",Output,Cancel=canc,"Constant Cutting Speed;0"=CCS, "or RPM (overrides above);0"=RPM, "Feed Per Rev.;0"=FPR,"Plunge Feed (Overrides above);0"=F
If canc Then
Exit
End If
If CCS = 0 Then
CCS = 1
End If
If F = 0 And FPR = 0 Then
F=.001
End If
If F>0 Then
FPR=0
End If
If RPM > 1 Then
RPM = RPM
Else
RPM = CCS * 3.8 / DIA
End IF
If F<=0 Then
F = RPM*FPR
End If
Ask Header="G83 PECK Drill (3 of 3)",Output,Cancel=canc,"Full dia. Hole Depth"=DEPTH, "Retract Height"=R, "Peck amount"=Q, "Return Mode;0"=MODE
If canc Then
Exit
End If
If MODE < 98 Then
MODE = 98
End If
If MODE > 99 Then
MODE = 99
End If
FD = DEPTH
If ANG > 179.999999 Then
Exit
Endif
dim T as Single
dim K as Single
dim DEPTH2 as Single
Pi = 3.1416
T = DIA - FLAT
T = T/2
K = 90. - (ANG / 2)
M = TAN((K) * Pi / 180) * T
FD = FD + M
M = M - M - M 'neg number
'Ask Header="Drill Point Calculator",Output,Cancel=canc,"Point Depth=;0"=M, "Full Depth;0"=FD
DEPTH = (DEPTH/UN) 'some thing bobcad did wrong!
DEPTH2 = DEPTH
DEPTH = DEPTH + M ' full depth
NCEdit Line = i,Output,Text=txt
txt = "S"+RPM
NCEdit Line = i,Text=txt, Output, NumLines=nl
NCEdit Line = nl+2
Generate
NCEdit Line = i+1,Output,Text=txt
pos = InStr(txt, "Z")
If pos > 0 Then
txt = left(txt, pos - 1)
End If
txt = "G"+MODE+txt+"Z"+DEPTH+" R"+R+" Q"+Q+" F"+F+" ("+DEPTH2+" DEEP)"
NCEdit Line = i+1,Text=txt, Output, NumLines=nl
NCEdit Line = nl+1
Window2
CamSoft.CBK HillBilly Machine Problems, Solutions , Wireless DNC, serial port 1 12-10-2009 05:15 AM
BobCAD to Solidworks (For sale BobCAD) Robert Lewis BobCad-Cam 3 05-11-2009 04:04 AM
BobCad offer to end all Bobcad Offers Syil_Australia Product Announcements & Manufacturer News 0 02-01-2007 05:07 PM
camsoft G1,G2,G3, DARYL CamSoft Products 9 06-22-2006 03:38 PM
