| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
I'm doing a retrofit on the Bandit. The Quickdraw changer has 11 inputs to control toolchange, spindle speed and tool selection. It has at least 1 input. These connections will go thru a 16 in 16 out relay card to get to the computer and Camsoft's software. Has anyone done this interface before? I have looked at Camsoft's example .cbk file and it seems rather complex. I am fairly sure I'll get the machine running but would like the toolchanger to work as well. Best'o'luck nelZ
__________________ i build the braces that keep american teeth straight......tick tick tick |
| I've used the Contec card attached to opto 22 boards on a couple machines. So far, I've done three different tool changers. The most important step is to understand EXACTLY how your tool changer should work. If you get lucky, there will be a toolchanger routine in a default .CBK similar to yours and it won't take long. OTOH, if you have a tool changer like on my CHNC that you have never seen run, you're not quite sure how it works, and some parts are broken; it can be a stone b&*( to get running. Karl |
| Supermax with Bandit III | damelman | Knee Vertical Mills | 3 | 08-23-2009 10:56 PM |
| Need Help!- Bandit in DNC Mode | Reder | Controller & Computer Solutions | 3 | 09-23-2008 02:52 PM |
| Shizuoka with Bandit Quickdraw Cover help | dodgy74 | General Metal Working Machines | 4 | 07-19-2007 04:19 PM |
| Bandit CNC machine | the | General CNC (Mill and Lathe) Control Software (NC) | 0 | 08-23-2006 02:22 PM |
| Bandit Control ? | jdelaney44 | Bridgeport and Hardinge Mills | 3 | 03-06-2005 08:36 PM |
