Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > CamSoft Products
CamSoft Products Discuss Camsoft PC based CNC controller products here!
Old 05-16-2008, 12:45 PM
normd is on a distinguished road
limit switch- home switch
I am using 1842/2900 combo can I set the 3 limit switches to double as home switches? How?
Norm D
Old 05-16-2008, 06:56 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Here's my macros to home and park off the limit switches. It saves a buch of time at startup if machine is in park posiiton so i tell operator to do this before shutdown.
'*********************************PARK MACHINE****************************************
[[PARKMACHINE]] 'called from M111
IF \140=1 THEN MESSAGE . Start of Park Machine
IF \141=1 THEN [GALILERRORS] 'message Galil errors
IF #59=0 THEN MESSAGE Need a Reset:EXIT
\124=f 'current feed rate
f=20
MACHGO ;;0
MACHGO ;0
MACHGO 0
f={\124}
MESSAGE Machine Parked
'**************************************HOME MACHINE*************************************
[[HOMEMACHINE]] 'called from M110
IF \140=1 THEN MESSAGE . Start of HomeMachine
QUESTION Is machine at limit switches?;\55;N
IF \55=Y THEN GOTO :STARTHOME
EXIT
:STARTHOME
MACHZERO 0;0;0 'set machine zero point temporarily for this macro
SUSPEND BYPASS 'suspends position checking for MACHGO move
MACHGO ;10 'move toward limit switch
WAITUNTIL #12=1 'foward limit switch Y axis
STOP 'stop when switch is hit
FINDINDEX 2;R 'find Y axis index mark
MACHGO -10 'move toward limit switch
WAITUNTIL #6=1 'reverse limit switch X axis
GO .05 'index mark too close to limit switch
FINDINDEX 1;F
MACHGO ;;10 'move toward limit switch
WAITUNTIL #13=1 'reverse limit switch Z axis
FINDINDEX 3;R
LIGHT 5;ON
\123=1 'flag for machine homed
MESSAGE AT MACHINE 0
Home/Limit on same switch? hargray2 General Electronics Discussion 1 04-02-2006 02:20 PM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 07:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 12:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
