| CamSoft Products Discuss Camsoft PC based CNC controller products here! |
Hi, I see that Camsoft is capable of 5 axis simultaneous machining but how well does it work and how easy is it to set up? I would be keen to upgrade my cnc machining centre to this open pc based system..any reports... good or bad..? Cheers John. |
| For how Camsoft works and ease of set up read this thread: http://cnczone.com/forums/showthread.php?t=19103 Camsoft will have no more trouble doing five axis simultaneous machining than it does with my four axis mill. This is because of the dedicated Galil motion control card (galilmc.com) that provides the real time motion control. I see Camsoft now offers a less expensive motion card, but I can't comment on it's capabilties. The difficulty will lie with a CAM package to program your machine, unless you're doing all manual Gcoding. Making the POST from this package work seamlessly with Camsoft will take some effort. Karl |
| I haven't done 5 axis yet but I researched it quite a bit. I feel pretty confident now that Camsoft will do well. It works good for us so far. I looked in to the 5 axis files they have and played in their development mode with 5 axis and it looks ok. Just like in 3 axis mode. They say they have a patent on 5 axis kinematics which I think this means 5 axis math but am not sure. You can watch a couple of 5 axis movies on their web site. They are hard to find and you have to enter your name and address and all that crap. Johnny |
| Thanks guys all very interesting information. I will chack the Softservo sight out too. Looking at all options here! I see what you are saying Karl. After seeing a few movies on youtube i am begining too see just how coplex and lengthy the G code is for simultaneous 5 axis... It seems that the 3d cutter comp/5 axis cutter comp is needed on the control HMI software....noticed that some HMI systems don't have this available yet! My idea would be to buy a cam package that will write the G code for simultaneous 5 axis for example Work NC or maybe Featurecam.. John. |
My son is a CNC programmer for an equipment manufacturer with several five and six axis machines. This is WAY out of my league, but I know he does all the cutter comp work within the CAM package. I'm always asking him to program for my 4 axis mill with cutter comp so I can change tooling and he just rolls his eyes. FWIW, he's a mastercam all the way guy. Best one out there and excellent support (almost as good as Camsoft's support ) Of course, a seat starts at about 12K.Karl |
| I see Karl..I noticed that in the Aerotech package they have a G21 for keeping a tool normal to a surface ie.tilting the surface and table or head and tool to keep the tip at the right angle to the part to stop it from gouging... I imagined the G code from a simultaneous 5 axis package uses this kind of tool normalcy and keeps the tool at the correct side of the contour as well but just wasn't sure how it handled the tool length offset when all 5 axis are moving simultaneosly. I'm sure it will all become clear to me sooner or later!! John. |
| By the way I think the softservo stuff stinks. I would rather trust the galil card to close the servo loop than their method plus I heard they have bugs issues and want to replace good working drives/power supply with the ones they use. Johnny |
Thanks, Ratrace2 |
#10
| I see Johnny, i was wondering about the bugs issue with these software packages but I have not heared anything bad about Camsoft on this front. It seems to work very well once it's set up as far as I can gather. Just not heard anyone report on the 5 axis routines yet!! John. |
#11
| Karl |
#12
| Hi citrona I have used the Galil cards to close the servo loop on three machine & would not use it again after using SoftServo Control I'm not sure the reason that you would say SoftServo stinks. ( maybe because they won't deal with you ) I have been running SoftServo Controls for more than 6 years & they do not have any bugs, As you say if they did there Engineers would fix it I have Mills with 3,4,& 5 axes SoftServo controls & are fitting 2 lathes with this Control right now & have never had any problems as you are saying Some of the Hardinge machines are using this SoftServo Control & many other high end machines also Also with the Drive problem, SoftServo would not make someone change there drives if they were any good If the drives were to old then the Galil card & Camsoft would not be any good either for there drives. The power supply that is needed for the system is 24v which is the Industries standard & is needed for almost all systems ( If they did not have this then they would need it ) SoftServo is not in the Drive Business but can supply Drives & motors / cables that are needed to get the job done. ( So they would not make someone change there Drives if they were any good ) They also usually only deal with OEMs so have very little setup problems, There system is almost Plug & Play And don't get me wrong CamSoft is a great control system & they are great people to go along with it But every system has it's place.
__________________ Mactec54 Last edited by mactec54; 03-07-2008 at 11:31 AM. |
| looking for 5 axis Simultaneous complete retrofit kit | racefast | Want To Buy...Need help! | 2 | 03-14-2008 09:39 AM |
| 5 Axis/face machining in Camsoft | alfalfa | CamSoft Products | 7 | 03-06-2008 01:04 AM |
| Software for simultaneous 5 axis machining | mudasser | General CAM Discussion | 12 | 02-20-2008 11:23 PM |
| hyper mill and 5 axis simultaneous...? | Richus | Hypermill | 3 | 10-11-2007 06:48 AM |
| camsoft and yaskawa axis controler | hugo cuvilliez | CamSoft Products | 3 | 05-25-2006 05:02 PM |
